Removing Tail light
Removing Tail light
Hey guys, need some quick help. I am in the middle of replacing my rear tail lights for 02+'s. I removed and replaced the right one with no problem. The left however is causing me difficulties. I removed all the nuts holding it in to place, but it won't come out. Is there some screw or something else keeping it from coming out that the right one didn't? I'm losing daylight and would REALLY appreciate some quick responses. Thanks in advance!
Originally Posted by PimPinTL-S
use alittle force not to much thow and it should pop out
Originally Posted by tpatel
are you sure you removed all the screws?!!? it would pop right out. maybe use a hammer and slowly tap on the screws
Getting a little frustrated. Should I just take it to a dealership to seek help? I'm almost at wits end with this one. Any suggestions would be GREATLY APPRECIATED!!!
@ slide or die @
try bumping/moving the headlight up and down and it'll come out...push it in and then try out again. I changed lights for s friend last weekend and had a similar problem.
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
