removing stock sub
removing stock sub
any diy on how to remove stock sub?
i'm going to attempt, anything i should know before doing this?
any info appreciated
remove teh little cover for the child teather, remove the bolt for the theather. then go in the trunk and unplug the third brake light's , then go back in the car and lift up and pull towards you on the sub cover (i may have missed something in there since its beed over a year since i did it) now you have access to the sub
Drive fast & swerve
Boomer SOONER
Originally Posted by z3Ro
its a sub?...i just thought it was just a bigger speaker...
yes it is a "sub" because it only plays the lower bass frequencies. Its nothing like an aftermarket one, but it gets the job done for the majority of the drivers...I am sure as hell not one of them though!
Originally Posted by IndyTypeS
out of curiosity, what are you putting in place of the stock one?
Drive fast & swerve
how do i locate the THIRD brake light wire?
R.I.P Red-CL
Hey uncleb that's exactly what I would use it for is my computer. I also was thinking that I'd just use it for the usb wireless network adapter(for net access) and the GPS unit---great concealed spot for it huh!!!
Boomer SOONER
Originally Posted by shimbo519
quick question, do you guys have your subs facing the rear or front of the car? Which is better?
brizzle, that's a cool idea
actually, what i meant is that i would use the sub, and put it in my room, since my room speakers are like 2" diameter. would the sub work fine if i box it? i know its supposed to be a free air.
although, now i thijnk about it, the stock sub area is a perfect place to put something....good thinking
get teh new PS2 (its a top load) and mount it there
That's a great idea also fsttyms1!!!
Mile High
i want to swap out the factory bose sub for a kicker comp 8" (free air). i think the factory sub is 9". would i need to get a new amp for the new sub, and would i need to make a special bracket to fit a smaller sub??
Boomer SOONER
the stock "sub" is around 1 ohm. So, you can power it with any amp that can power a 1 ohm mono signal. From what I have heard, you might as well replace you stock sub and amp and get a new setup...The sound improvement from the stock system to my system is amazing. I dont recommend being cheep in this situation - trust me, it will make your everyday driving experience more enjoyable.
Originally Posted by jayhawk815
It probably won't work all that well in that application. Also, how are you going to power it?
i really don't know, i mean, i figured since i'm going to take out my stock system, i might be able to box it and power it, i can probably use the same amps that were powering it in the car....i really have no idea though, i don't even know if i would be able to get the proper wiring. also, i don't know what source to hook it up to. its no big deal really, i just figured i could use the system for my room, and at the same time get some box building skills....i have no clue if a free air works well in a box though, and if so, what kinda box to put it in.
o yeah, i got a brahma and usamp 1000x that should hopefully be here soon.
mabye not the best of the best, but i did my best to find what deals i could, and this seemed pretty cost efficient compared to what i should hopefully get out of it....i'm a rook though, so i don't know how anything's going to turn out
Joseph Stansbury
34
12-04-2015 01:57 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
