removing the door panel
Old May 13, 2005 | 04:45 PM
kcho1200's Avatar
Save driver
Question removing the door panel
Hello everyone,
Is anyone can show me how to remove the 2000 TL door panel, i think i need some pic to understand. and i did try to search on this site, but i wasn't able to find any thing.
Plz help !!
THANKS
KC
Old May 16, 2005 | 09:10 AM
dchondasport's Avatar
2006 TL ASPEC
Try the Search.
It's in there.
Originally Posted by kcho1200
Hello everyone,
Plz help !!
THANKS
KC
Old May 16, 2005 | 09:58 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
It's very easy.
Look under the door panel's arm rest, there is a hole with a screw at the bottom of it, just unscrew it. Then, look behind the door handle, there is a little plastic cap, take it off with a flat screwdriver (be careful not to mess up the plastic). Behind it, you will find a black screw, take it off. Then, carefully pull on the door panel starting from the bottom and slowly working your way up, it should come off just fine, but might need some force because of the clips that also hold it in place.
When the door panel is detached from the door itself, reach between the two and disconnect the wires going to the alarm LED, windows switches, door lock, etc.
I hope this helps!
justin
Old May 16, 2005 | 04:30 PM
whatwasthat's Avatar
there are basically only two screws you have to unscrew like @cur@-TL said. the hard part is understanding that the panel is held on by clips... just have to pull the panel out to unclip it (start from the bottom, then go up). if you want pratice first( or if you're scared of breaking something - which you won't), try removing your door sills. they are held on by the same clips.... and for door sills, there aren't any screws, so just pull and you're done.
also remember that the door panel is ONE whole piece.
Old May 16, 2005 | 04:32 PM
oh , forgot to mention to be careful of the door handle... i had to disconnect the metal rod from the white plastic part it is connected to to completely remove the door panel and put it aside..
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
CadiGTi
Sep 14, 2015 06:37 PM
04tler
Sep 10, 2015 01:13 PM
