Removing Dash Board
Removing Dash Board
Does anyone have instructions on how to remove the top of the dash board? I need access underneath it to run some wires.
Thanks for the help.
Moderator Alumnus
Why not go under the dash....you can easily remove the underpael beneath the steering wheel and push the wire through to the other side with you hand and then remove the glove box, etc...
Thanks for the tip. I was hoping to be able to install a fixed GPS antenna (approx 1.5 x 1.5 inches) adjacent to the temp sensor. I looked at installing it on the aft hat rack, but didnt want to take the whole interior off to run the coax up front to my Garmin unit. I think the easiest would be to mount the antenna up front....
Moderator Alumnus
If you take your hand and head to the top right of the gas pedal there is a small tunnel that connects the both sides of the footwells. There is plenty of space in there for that and the only thing on top of the antenna would be the heater ducts most likely so there should be little or no interference.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
