Remove front and rear mud guards?
My TL-S is less than two weeks old. It seems that people here are saying that they scratch the paint. Should I remove mine ASAP?
Who says that they scratch the car?? Those r supposed to prevent road debris and water from hittin the sides of ur car..They dont scratch they protect...Who ever said that they scratch must b a dumb*ss..!
Received 1,080 Likes
Hey newbie, you be the dumbass b!tch.
They most certainly do scratch the paint. They dig into the paint on the side of the car where they hit the fender.
Search the forum and you'll see pics of the damage they cause.
Welcome to A-tl.com :flamer:
Originally posted by DaBeerSnob
I've had mine on since I got the car in May 2001. No scratching or damage yet.
DaBeerSnob
2002 Aegean Blue Type-s
DaBeerSnob
you will regret saying that.
I think you should search before calling anyone here a dumba$$.
Yes Pauli,
remove it as soon as you can. I'm sure someday you will want a bodykit on your car.
I spend hours and hours trying to buff it out and there's still little marks on the front.
i've tried, paintscrub, scratch x, bug and tar remover, and whatnot but the marks still visible when looking up close.
Having Fun?
Doh!
BTW - Welcome to the Boards, good to see another Mass peep!
Re: Remove front and rear mud guards?
Here's the scoop: If you think you'll want a body kit installed sometime, then you'll find out that mud guards and a kit are mutually exclusive (can have one or the other, not both). When you remove the mud guards to install the kit you'll find out that they've been scratching your paint *behind* where they were attached. However, now that you've removed them for the kit, the scratches are easily visible.
That's why people are saying to remove your mud guards as soon as possible if you are considering a body kit.
Got it?
V.
If some of u were smart u would take off the mud guards and put double sided tape on the parts of the guards that contact the body of the car....Its a lil common sense that helps if u would kno!
My only problem now is I get mud and crap kicked up along the side of the car. Give and take I suppose. Was thinking about getting some cheap flat mud guards like that other guy on this form did to go along with the mud guards.
Given all this talk about scratches, I took a look at my factory mud guards last night. One question: how do you remove them? Obviously, you unscrew the screws, but the space between the tire and the screw is pretty small. I have a set of those small stubby screwdrivers (less than 3" total length but full size heads), and even those are too long to get past the tire. Do you have to remove the wheel to remove all the screws? Also, after you remove the mud guards, do you just rescrew the screws back into the holes? Any suggestions would be appreciated.
Yes, if you're not putting the bodykit at the same time, then you'll have to rescrew it back.
By that reasoning, those people with body kits should remove them 'cuz surely they'll leave marks on the paint too...
Sheesh--what kind of damage will mud guards do to the paint that you can't even see anyway unless you remove them?
In any case, if you're that concerned about the damage they'll do, then a little preventive maintenance like what someone else here described should take care of that.
09-04-2015 08:03 AM
