Release gas pedal when SS shift?
Old 01-30-2004 | 05:34 PM
thsiao's Avatar
Happy with my STi!
Question Release gas pedal when SS shift?
Do you guys release the gas pedal when shifting during SS mode (like people would in manual cars)?
Old 01-30-2004 | 05:43 PM
hzm82's Avatar
There is no point, SS isn't a manual. Just floor it and shift.
Old 01-30-2004 | 05:54 PM
Pure Adrenaline's Avatar
Dragging knees in
No, I keep my foot planted.
Old 01-30-2004 | 06:03 PM
Dr. TLS
I do sometimes, especially when I'm downshifting to 3rd at 60mph+. You will notice that if the throttle is applied too far, sometimes "3" will blink on your dashboard if you downshift at a fairly high speed. THis means you will go over redline and the ECU is preventing you from downshifting for this reason. At times like that, you have to let go of the throttle to make sure you get the power you need.
Old 01-30-2004 | 06:08 PM
fsttyms1's Avatar
before down shifting i blip the throttle to help rev match
Old 01-30-2004 | 06:33 PM
spl1011's Avatar
I often do, by habit - I love manuals!
But its not necessary, and quite frankly, I letit do what it is designed to do. I am paranoid that If I mess with it, I may stress it somehow.
But no need.
Old 01-31-2004 | 09:38 AM
Ianbiz3's Avatar
lol, u should let up a little bit
Old 01-31-2004 | 10:19 AM
spl1011's Avatar
your right, floor it and shift!
Old 01-31-2004 | 10:21 AM
Dr. TLS
It won't always downshift then for the reason I mentioned in my post above.
Old 01-31-2004 | 10:32 AM
njtls's Avatar
no reason to let up....totally pointless...its still an auto trans except your telling it to shift instead of the computer
Old 01-31-2004 | 11:19 AM
goldendragon576's Avatar
TL-S driver
only when i downshift to pass.
Old 01-31-2004 | 11:20 AM
fast-tl's Avatar
I love cars!
fsttyms1,
there is no manual "rev matching" you can do in an automatic transmission. Blipping the throttle with the clutch disengaged will allow the engine to rev enough to match driveline speed before releasing the clutch, but there's no equivalent to that situation in an automatic.
Ferrari comes closest to what you're describing, but their paddleshifting transmission is a manual with computer aided shifting, in that during a downshift the computer disengages the clutch, blips the throttle (for you) then engages the lower gear for smoth shifting.
Again, an automatic takes care of this using its torque converter. The only way to do this in an auto is to **** to neutral , rev the engine, then put the car back in gear. There's no need to for this.
Old 01-31-2004 | 11:43 AM
fla-tls's Avatar
On the way!
Agreed - I do the same thing. If you don't the car lurches forward when it downshifts. It just feels like you're hurting the tranny/torque converter.
Old 01-31-2004 | 12:14 PM
spl1011's Avatar
yeah, but trannies try to reduce the revs during an upshift.
Sometimes its not 100 percent smooth and you feel the lurch.
I have yet to meet an average or above average driver that can shift gears at full throttle smoothly with as minimal "lurching" as and automatic.
Usually you slam the gears in quick and pop the clutch. Gotta love the tire chirps when shifting from first to second!
Old 01-31-2004 | 12:24 PM
fla-tls's Avatar
On the way!
fsttyms1 and I were talking about downshifting. There's no need to let off the gas on an upshift.
Old 01-31-2004 | 04:17 PM
fast-tl's Avatar
I love cars!
Guys, here's a simple description of rev-matching. IT'S NOT POSSIBLE WITH AN AUTO TRANNY!
Rev-matching is putting the clutch in, giving a little gas to get the engine up to the correct speed for the lower gear, and letting the clutch out.
Double-clutching is putting the clutch in, shifting to neutral, letting the clutch back out, putting it in, shifting to the next gear, letting it out. (Double-clutching usually includes rev-matching, but that's the basics.)
Old 01-31-2004 | 06:25 PM
fla-tls's Avatar
On the way!
Well, whatever you call it, it feels and sounds better when you blip the throttle when downshifting.
The transition is much smoother.
Old 01-31-2004 | 07:02 PM
livinglegend's Avatar
ULOOZ
Plant the right foot, listen to the revs , and give another gear. Then SMILE
Old 01-31-2004 | 08:44 PM
Ianbiz3's Avatar
it wont shift, only downshift
SidhuSaaB
05-30-2020 12:40 AM
Popee
12-20-2015 12:08 AM
kixo
09-25-2015 03:07 PM
Hines57
09-24-2015 01:58 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Release gas pedal when SS shift?
