Recommendations for brake upgrade
ARide for Life
What do you guys think i should do?
Legend calipers or go with a front BBK?
Ive been looking at the willwood kit, brembo and rotora are a little out of my price
legend calipers, drill and slotted rotors. ebc red stuff pads.
all i need is the calipers and im going nsx bc they have the nsx stamped on them. my brakes stop crazy fast with no brake fade.
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
If you get the NSX calipers they are about $100 each at rockauto (thats if they have any last time i called they only had driver no passenger) and good rotors DBA or EBC r gonna be $200 a pair and pads would be like $60-$100 for good ones and stainless steel brake lines r $100 so
$200 both calipers
$200 both rotors
$100 pads
$100 SS lines
= $600
You can get Willwood for like $700 4 piston calipers that look sweet..
I have NSX calipers up front and am getting a anooying rubbing noise but i think its the metal bracket on top of the inside caliper and If I can do it AGAIN i would prob go with the WillWood brake kit..
Does anyone have a WILLWOOD kit that can chime in and let us know how it is?
$200 both calipers
$200 both rotors
$100 pads
$100 SS lines
= $600
B A N N E D
Oh yeah and my NSX callipers are RUSTY as hell I guess when they rebuilt them they did not put and coating on them!
Funny how the bracket does not rust but caliper does!
B A N N E D
Yes but is was the idiot that put them on kinked the line to make it fit and fluid was getting trapped!
On the NSX calipers where the brake line gets screwed on is lower on the caliper then the OEM so instead of unscrewing the screw that hold the brake line and fixing it he spun and pulled it untill it was kincked!
legend calipers are better than nsx and cheaper, the legend 2nd piston is bigger than the nsx, seach the forum for the exact numbers. (84 after core charge at rockauto). Also back when i was looking at the wilwood set i read a lot of reviews about willwoods rotors in general warping easily.
B A N N E D
the legen calipers have to be reversed cuz they are trainling edge and if you put the right on right and left on left then the bleeder will be upside down do u have to reverse them.. Yeah i don't think 1-2MM makes a difference.. I was not comfortable putting a driver side caliper on the passenger side nor was i comfortable having the bleeder upside down and bleed ing the calipers off the car!
B A N N E D
yes there are a few years ONLY that fit I think 96/97 but I am NOT POSSATIVE do a search there is alot of info on this upgrade. B4 I did it I searched and found many pages of info on here so B4 ordering make sure u get the correct years.. I know the 200? will not do..
with the probs the stoned had,, and the supply of legend calipers greatly exceeding those of nsx- I would stick with the well proven 1995 Legend LS-C caliper bolted to the stock tl bracket, rotors, and pads
Paint them black and rust or looks isnt an issue
Its not prob running them reverse of `marked`
That noise you are hearing is the big spring plate hitting the TL rotor edge- throw it away
B A N N E D
I would go with the Legend calipers for this exact reason. What happens if you have a sticking caliper and cannot get a replacement? Sure it could be rebuilt, but what if you can't rebuild it?
Former Sponsor
The Wilwood kit is a good street kit:
http://store.excelerateperformance.c.../i-236893.aspx
12.6" 1 pc rotors, Wilwood 4 piston calipers. Reasonable price.
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
