rear view problem
Old Jan 16, 2003 | 11:18 PM
Cobra's Avatar
5th Gear
rear view problem
Does anyones auto diming rear view work I cant see any difference in mine at night how do you test it?
Old Jan 16, 2003 | 11:23 PM
iliveinapathy's Avatar
press the button to the left ( if u have onstar)... if u dont itll bethe only button there, have someone shine a flashlight through the rear windshield and see what the difference is when the button is presseed.. And then when the button isnt pressed…
Old Jan 17, 2003 | 05:58 AM
After you push the button, give it about 15-30 seconds to dim or un-dim. It isn't instant. If you wait, it should happen even if someone isn't shinning a light from the rear. You can see it change in daylight.
Old Jan 17, 2003 | 10:25 AM
What button are you referring too?
Old Jan 17, 2003 | 10:43 AM
InspireSaber's Avatar
Both PlanoTLS and iliveinapathy are referring to the auto-dim button which is located on the middle bottom (non-Onstar) of the rear view mirror. When pressed, a small round green light will appear right above the button indicating that the auto-dim feature is on. When pressed again, the auto-dim feature will turn off as well as the green light.
Old Jan 17, 2003 | 10:47 AM
AndySara's Avatar
Run your hand under the rear view mirror. You should feel a button. That is most probably the one he is referring to.
Old Jan 17, 2003 | 12:54 PM
what year is your tl? i think some cars (not sure about older tl's) have an automatic one with no button option
Old Jan 17, 2003 | 03:48 PM
VeeDubDude's Avatar
run your fingers along the BACK of the mirror near the windshield. you should feel a small depression where an ambient light sensor is located. cover it with your fingers and wait a few seconds. by covering this sensor, the mirror will think it's "night" out. the ambient daylight around/behind you will be interpretted as headlights and the mirror should dim.
Old Jan 18, 2003 | 03:11 PM
i thouhgt the sensor for the dimmer was in the back of the rear view mirror. because when i had my parking permit for college and used to hang it on the rear view mirror and i noticed it was dim in dayligt and then when i took it off it un-dimmed...
mada51589
Jan 9, 2025 04:40 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
jspangan
ILX
19
Aug 30, 2016 05:37 PM
Rocktman1
Oct 31, 2015 02:33 PM
dre707
Sep 8, 2015 08:32 PM
