Rear Tie Bar from Accord
WhizzBomb
Hello,
Someone once talked about getting a rear tie bar/strut bar for an Accord that would fit the 2nd gens.
1.) Can anyone confirm this?
2.) Has anyone hear done it?
3.) Is it worth it?
Thanks,
Joe
3.) Is it worth it?
Thanks,
Joe
I remember reading something like this too. I think he used a rear lower tie bar from an AV6 for the 2nd Gen. I think it was an eBay bar too. I don't know the details but I would love to do this too.
Originally Posted by Whizzbomb
Hello,
3.) Is it worth it?
Thanks,
Joe
3.) Is it worth it?
Thanks,
Joe
2) It was done by someone on the other website.
3) Not sure if it's a good mod to do or not, not enough feedback from people who have done this. Adding a lower rear tie bar would stiffen the chassis in the rear, but I'm not sure how this would affect handling in understeer or oversteer situations (if at all).
i've seen a few threads of people here doing it. they got good results. keep in mind though tht it will throw your alignment off so you will have to have your car re-aligned.
Originally Posted by joseph_99tl
i have one.
and installing didn't alter the wheel alignment.
i have one.
if you just remove the bolts and place the bar on, then tighten, your good to go .
the rear alignment is locked in by cam washers with teeth on them.
as long as you don't move the car with the bolts off, you'll be fine.
i felt just a little tighter in hard turns....hardly noticable..
i got it off ebay.
98-02 honda accord rear tie bar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33591
Boomer SOONER
i got it off ebay.
WhizzBomb
i got it off ebay.
Originally Posted by ou sig
wow...dont know about the quality but that is cheep for sure. Where does that go? I know we have that rear sway bar, but where would this bar connect at?...and isnt that just the same idea of putting a stiffer rear sway on?
Do you have any idea which would fit at 03? The new generation of Accords?
Originally Posted by patrick
Thomas, it's just like the Cusco lower front tie bar, but it's for the rear. Nope, not the same as a stiffer rear sway. The tie bar stiffens the chassis, to prevent chassis flex during high speed cornering. Sways don't do this I believe.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
the sway bar will reduce roll, this will reduce chassis flex.
cycdaniel
12-17-2019 10:58 AM
marcelft
07-10-2018 06:17 PM
