Rear Sway Bar (Progress)
Old 02-08-2008 | 05:57 PM
Doc Holliday's Avatar
Question Rear Sway Bar (Progress)
ok for our 2nd gen... this one is supposed to fit even though it says it's for a 3rd gen
my question is if anyone has this on and has messed with the two settings?...
There is stiffer and softer.
I don't want to feel every bump on my ass... so just wondering how much of a diff it could possibly make... I want less body lean on turns, so that's what I was going for...
I would hate to feel every bump on the road so hmmm... as of now I'm going to have him set it on the stiffer setting and just go with that.
I thought softer and stiff could only be a a shock/spring thing hmm?
Old 02-08-2008 | 06:43 PM
SRAcuraTL's Avatar
I would go stiffer. I don't think it'll make a lot of difference when your just cruising when it comes to feeling the bumps in the road but it will handle better and have less body roll when railing corners.
Old 02-08-2008 | 06:50 PM
01tl4tl's Avatar
soft is for street use, stiff is for track days- see their website
Old 02-08-2008 | 08:17 PM
this is what I found so far
http://progressauto.com/store/produc...roducts_id=394
Old 02-08-2008 | 08:23 PM
I also checked the faq... hmm
I just wanna notice a difference and make smoother turns at a little higher speeds...
I'm not going to race, but I am considered an aggressive driver...
I also, wouldn't want to spend the money and place it on the softer setting and not notice a difference...
Old 02-08-2008 | 08:36 PM
Never Summer's Avatar
With how much thicker the bar is than stock, you should notice a big difference. This is one of the things on my list to get done.
Old 02-08-2008 | 08:38 PM
01tl4tl's Avatar
Unless you are driving at constant race track-day speeds, meaning the tires protest, then that bad noise goes away in the turns as you go faster and a little bit of slide is normal, when you are focused on placing and setting the cars nose for turn in at exact points, and weight changes in cornering- apexing...all at max effort braking and turning effort, and back onto full throttle to the next turn....
soft will be fine to start with~
You dont put adjustable shocks at max firm to start either.
See what it does at soft/normal, and its a quick change to other setting
Just the increase in bar diameter/size- and poly bushing vs rubber, bar mettallurgy etc,
its going to stiffen the cornering up plenty for the normal human.
I have seen other ads for it where they talk about soft for streetable and stiff for actual race track type use- or hardcore mountain fun runs.
I run my Tein SS shocks softer in back, more for handling than comfort
marcelft
07-10-2018 06:17 PM
Onyxthecat
10-18-2016 02:05 PM
drone619
01-26-2016 07:09 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
Quick Reply: Rear Sway Bar (Progress)
