rear rotor help
Old Sep 5, 2004 | 02:19 PM
NYZGREATST's Avatar
Sig Rho's Finest
rear rotor help
im trying to replace the rear rotor. i got the caliper off. i got the two screws that hold the rotor in place off. but the rotor wont budge. is there something i am missing here?! thanks
Old Sep 5, 2004 | 07:14 PM
jeffcoseo's Avatar
7th Gear
just replaced rear rotors
funny, I just got done replacing my rear rotors 20 min ago. And I had a b.... of a time getting those rotors off. Turns out, I don't use my E-brake very often, and there is very little clearance btwn the rotor and the e.brake pads. Easiest thing, align the open hole with the bottom of the brake, use a flat-head and adjust the e.brake to less pressure. Or, give me an email w/ your phone number and i'd be glad to give you a ring.
-Jeff.
Old Sep 5, 2004 | 09:02 PM
benzo555's Avatar
boo
Use a small mallet and pound it. It will come off eventually. Also you may want to grab the rotor with two hands and just shake it and should loosen up.
Aug 15, 2019 12:58 PM
yesSIR-S
May 13, 2016 05:42 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
