Rear Lights keep on burning out
Old 11-14-2003 | 10:04 AM
TeknoKing's Avatar
Question Rear Lights keep on burning out
Hello,
I have this mystery in my TL'00
The rear break bulbs keep on burning out. I replace one bulb, drive for a day, everything is fine, then the Break Lamp warning goes on, and this time it is a totally different break light bulb that burnt out. I replace that....in other words, I already had to replace all four rear bulbs(break lights), one by one, one after another. So it is not the same bulb thats burn out all the time. WHAT CAN IT BE?!? I'm losing my mind.
Help, Thanx =]
I was also wondering, does anyone have this weird thing happening where you see the lights inside the car vaguely flicker for less than a second (once in a while)?
Old 11-14-2003 | 10:33 AM
Strannik's Avatar
When this happened to me with 3 of my bulbs, I just replaced the rest of them and have not had this problem for almost a year now. Looks like our bulbs burn out in about the same time.
Old 11-14-2003 | 11:14 AM
doopstr's Avatar
Re: Rear Lights keep on burning out
Originally posted by teknoking
Hello,
This is most likely being caused by your air conditioner cycling on/off.
Old 11-14-2003 | 11:25 AM
Replace all bulbs at the same time.
Old 11-14-2003 | 01:36 PM
maxx96's Avatar
New Life
Re: Re: Rear Lights keep on burning out
by what?
Old 11-14-2003 | 01:51 PM
goldendragon576's Avatar
TL-S driver
Stop stepping on your brake so much. Use the gas pedal!
Old 11-15-2003 | 12:41 PM
TeknoKing's Avatar
thanx for the advice, i replaced all bulbs, everything is fine, except the damn Break Lamp light is still on....its frustrating ;/
thanx again for the info guyz
Old 11-15-2003 | 02:52 PM
beefstew's Avatar
yeah the taillight bulbs that came in the earlt tl's were garbage...they actually updated them...in regards to the brake light still being on i've seen some aftermarket buls cause this...did you get em from the dealer?...HTH
Old 11-15-2003 | 05:17 PM
TeknoKing's Avatar
No, i bought them at Autozone. The bulbs that burnt out were all stock (Japan made), so lets how American babies hold up lol
Old 11-15-2003 | 08:34 PM
ChucksCL-S's Avatar
Solved my same problem by not touching the glass part when putting them in...only touch the base as oil from your fingers gets on the bulb and overheats it or some nonsense but it worked!
Old 11-16-2003 | 01:42 AM
TeknoKing's Avatar
i did that, thanks, everything is fine now =]
Old 11-16-2003 | 07:37 AM
doopstr's Avatar
Re: Re: Re: Rear Lights keep on burning out
Originally posted by maxx96
by what?
You have never noticed that? I have noticed it on every car I have owned. If you are stopped at a light and your compressor kicks on that puts a sudden load on the engine. As a result the alternator has a small drop in voltage output. You will see your dash board lights dim for a second. Interesting thing on this car is that the HIDs do not dim. My other cars had halogens and the headlights used to dim for a second.
This doesn't happen while cruising because the engine is at a higher rpm when the compressor kicks on.
Old 11-16-2003 | 11:23 AM
TeknoKing's Avatar
hmm, I had a Maxima before, with a lot of custom lights on it (interior and exterior), 2x12" woofers sucking power, extra gauges, and it never dimmed.
Thats why i was worried about my TL dimming. Maybe i need to change my battery.
Old 11-16-2003 | 10:06 PM
vtec 6300's Avatar
My 2000 Accord 4cyl rpms jumps when I am at a stop light when the AC is on. It's pretty annoying and you can feel it. Doesn't happen when the car is moving. But when I am in my 2003 TL with the AC on at a stop light, I don't really feel the compressor kicking in. Any ideas?
Old 11-17-2003 | 02:54 AM
TeknoKing's Avatar
does it stay below 1000 rpms?
read what doopstr said above, that could be a valid reason as well.
Plus, I would assume that TL would be better built than an Accord.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
IIDXholic
10-08-2015 07:53 AM
Ny1718
09-11-2015 09:21 AM
Quick Reply: Rear Lights keep on burning out
