rear door speaker cover
is there a way to remove the speaker cover on the rear doors. i didn't see a little notch like other cars have where you can stick a flat screwdriver in there to pry it out. does the speaker cover come out, or would i have to remove door panel?
thanks. oh, i have a 99 tl.
All doors are pretty much the same, except the driver's door has more wire harnesses to
unplug.
Start by removing the big screw in the armrest, then the little screw behind a little round
cover behind the inside door release. slide the door release mechanism back about 3/8"
and pull out. There's a little plastic catch on the metal bar--unhook it and remove the
assembly.
The door cover is held on by plastic friction clips. They're pretty forgiving of being pulled
up without the proper tool. (Buy the tool though--it'll come in handy).
unplug.
assembly.
DiamondJoeQuimby
09-10-2015 11:40 AM
09-04-2015 08:03 AM
