Rear Brake Caliper Tool Acura TLS
What kind of rear brake caliper tool is need for the TLS? Can I use a univerals caliper tool or do need some something special from Acura Deal or Snap On? The tool is for depressing the rear caliper piston.
unless they changed it from the 00 design they just push in like the front (with a larg C-clamp or channel locks)
Need a WHAmbulance
Yes, rear calipers should *not* be compressed in, but need to be screwed in with a tool. This is because of the integration of the emergency brake into the rear braking system, and is true with just about any modern car with rear disc brakes. A pair of needlenose pliers will work in a pinch but you're better off getting the adaptor to do the work. I know AutoZone stores will loan you their disc brake caliper tool (which has a bunch of adaptors for various makes/models) for FREE. You just need to put down a deposit on a credit card and then you get it credited back when you return the tool.
Originally Posted by fsttyms1
mine did not screw in. they push in. the parking brake on the TL isnt integrated with the rear caliper. it is a drum brake.
Originally Posted by njtls
well either way..the parking brake is a drum brake
Retired MOD
1 Post
I know for a fact that the '02 and '03 TL-S models definitely screw in.
Do you have any pics of the rear brakes without drums (drums are for emergency brakes)
Cars with screw in calipers also have the emergency brake cable attached to the caliper itself....
Originally Posted by Bitium
I know for a fact that my 99 is not screw in and I really doubt it that any TL is screw in.
Blown is Best
Be careful just pushing or spinning the piston back in. When you do so, you run the risk of pushing sludge and debris from the cylinder back into your ABS unit. You typically want to open the bleeder valve and let the old fluid expel when you push or screw in the piston.
