Rattle when accelerating
Old Feb 21, 2006 | 07:17 PM
tom5683's Avatar
I have been having a rattle that sounds like its comming from the right side of the car, some where underneath the middle. This only comes when I accelerate. I can play with the gas and hear it when I push down, and then stops when I let up. Any ideas what this could be? It seems to be more noticable at lowet speeds and RPMs. I searched and the only thing I could find is the heat shield? Could it be muffler, etc.?
Old Feb 21, 2006 | 07:27 PM
fsttyms1's Avatar
id say maybe a heatsheild? Is id deffinatly outside teh car and not something in it?
Old Feb 21, 2006 | 07:35 PM
tom5683's Avatar
Yea its forsure outside the car, sounds comes from the passanger side.
Old Feb 22, 2006 | 02:42 PM
monky's Avatar
I got the same problem, its resonates esp. at 1.8k rpm. Sounds like rattling in the door or pillar.
Haven't had time to really look into it. Let me know if you figure it out.
Old Feb 22, 2006 | 03:44 PM
phipark's Avatar
Not Asian
Maybe the cat heat shield.
Old Feb 22, 2006 | 04:56 PM
jam9011's Avatar
Acura TL 2005/6spd
I HAVE SAME PROBLEM MINES COMES FROM DRIVE SIDE IT BEEN GETTING ON MY NERVE I PICK UP THE MUSIC SO, I DONT HAVE TO HEAR THE RATTLE. THE GREASE MONKEYS FROM ACURA DO NOT KNOW HOW TO FIX THE PROBLEM WHEN I WHEN TO SERVICE THE CAR. I DONT KNOW WHAT TO DO
Old Mar 2, 2006 | 10:51 AM
monky's Avatar
I was on a long trip with my girlfriend and she tracked down the noise to my sunglasses in the sunglass holder.
So take it out and see if it still rattles.
I hope that helps.
-Jimmy
Old Jun 22, 2006 | 10:51 AM
victorvu's Avatar
i got the same problem the heatshield is tight. maybe a the cat? if the cat is cracked wouldnt it throw off the check engine?
Old Jun 22, 2006 | 12:09 PM
NSXNEXT's Avatar
Not necessarily. Small pieces can break loose inside and the cat will still function properly. Check the heat shields first. It's an easy fix.
Old Jun 22, 2006 | 12:34 PM
bkzjimmy's Avatar
NiGhT rIdEr
i had a problem like this on my old 96 accord..... it was a cover somewhere on my exhaust, my mechanic put it on a lift ripped it off and say bye.
Old Jun 22, 2006 | 12:39 PM
NSXNEXT's Avatar
Yeah the heat shields are not a necessity. Just don't park your car over top of dead leaves.
Old Jun 22, 2006 | 05:24 PM
brado's Avatar
new wheels = old school
i think they are dual purpose though...the heatshields or 'cover' as in the parts manual. they are there so rocks won't fly up and puncture the cat i believe too, not just for a heat barrier. but if you want to risk a 600 or 1000 dollar part if you are a type S driver, take that cover off then.
Old Jun 22, 2006 | 05:30 PM
fsttyms1's Avatar
Id like to see that thin little sheild stop a rock. If its strong enough to puncture the cat, it will blow right thru the shield with out even batting a eye.
Old Jun 22, 2006 | 05:42 PM
brado's Avatar
well if kris, the god of acurazine says so, then it must be true.
Old Jun 22, 2006 | 05:45 PM
MisterLinus's Avatar
I have Lucy tied up in
I had this same problem, it was the heat shield for me located over the front right cam shaft. They replaced the shield under warranty and I haven't had a problem since.
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
