Ram air intake complete!!!
Any of you that are familiar with the M5 may know about the IN500 intake. Basically it works like this: two 4" holes are cut in the lower front grill of the M5, and a tube is run on each side to the intake boxes. The M5 gets 30 HP from this. If course, it only works at highway speeds. So my buddy and I decide to do it to his M5 last night, and it worked great. We used 4" dryer tube, and PVC drains painted black as the flange.
So I said why the hell can’t I do that?
So today, I did it. I popped off the intake box, the bumper, and the massively oversized resonator. God that thing was huge. I couldn’t believe that my engine breaths through that tiny-ass little tube...
I cut a 3" hole in the driver’s side place on the bumper where the fog lights would go on the new TL's. Using a 3" black painted PVC drain with the grill of the drain cut out. 4" dryer tube adapted to fit the 3" flange. I ran the dryer tube to the 3" hole where the resonator used to connect to the air box.
So I took it out for a little test drive, and I'm impressed. Up till about 45-50 MPH obviously there was no improvement, but after that, my TL-P had a very noticeable difference in performance. When ever I’m moving faster than 45, I can hear it eat the air its being forced. It’s nice and deep!!
At 80 MPH, i can drop it in to 3rd gear and then i really see the difference. It takes alot less time now to get to 110 MPH
I already ordered the K&N air filter so I can get that much more air, as I’m sure the stock filter is causing a little air restriction.
So what do you guys think? I’m surprised no one ever did this before. I did have to cut the corner of the frame a little so the tube could line up properly, but nothing big. In the end it was real easy.
Total cost: $10.56
Nice.
-ME!!!
Total cost: $10.56
Nice.
-ME!!!
Sounds good, try to get us some pictures! Also, will someone teach me why these systems don't injest alot of water during heavy rainstorms? They must not or the factory wouldn't use them. I'm guessing not much water makes it in there. I don't mean submerged in water.
Actually it will kinda work itself out in the end. If you know what dryer tubing looks like, you know that it’s comprised of a metal spiral lined with metallic plastic. There’s only 2 ways water hits the lower part of your bumper. Driving through a puddle, and a damn deep one at that, and rain.
A little bit of water is ok. Even if I dumped a glass of water in the hole, it would still have to travel 2 feet to the air filter, completely soak the air filter, and lock my motor. Even if the water gets to the air filter, most of it would vaporize and explode when it hits the combustion chamber. If an OUNCE got through the air filter, well, that would suck. But I can’t see how that would be possible.
The great thing is that because the OE air box is still there. With a CAI, the filter is 5 inches from the splash guards. The stock filter is 2 feet. You get hydralock from a CAI because the filter gets submerged, which is not possible in this case. Hell, even if I stuck a frickin garden hose in the new hole of my bumper, I bet I could pull the filter and it will still be dry.
Only bad thing is that I will now have to check and clean the air filter much more often, as now more dust/dirt/bugs and other crap will get sucked up more easily...
-ME
-ME
Originally posted by randomwalk101
well that if you have stock intake..but most of us have CAI and air is being sucked at the bottom thus giving the same effect with much cleaner look...of course, ain't $10 though
-me
Originally posted by A$IAN_CHICKEN
**** you mother****er random****in'walker ****in' racist bastard
What the F*ck is wrong with this dude? This f*cker needs to be banned and his ass needs to be sticked on top of a flag pole.!!!
Well, if everyone wants to know, randomwalk101 was mockin' ASIANS..... and got flamed hard in a post, which was recently removed....
you know why.... 'cuase you cussed out all asians in a thread that was removed from this site.... why don't you tell everyone in here what you said?
I had the resonator removed (the ugly airbox behind the bumper), and the Comptech Air Filter Element. It's got a deeper sound, as opposed to the CAI, which is a loud shriek at WOT. IMHO, it sounds a lot better combined to a nice exhaust.
Ed
Ed
-ME
-ME
ever try compressing water? nope, it can not be done. so imagine if you got just a little bit of water in your engine and your piston tries to "compress" it - i can assure you that it will not just vaporize. certain companies offer bypass valves for their CAI b/c of the risk of blowing your engine if water were to get into it. and jesus, why would your friend be tinkering with an M5? that is one fine specimen that the weekend mechanic should not be tinkering with.
Originally posted by jomama
hey buddy,
hey buddy,
As for the M5, that upgrade is an actual product avaliable. its $1000 and looks a little nicer than what we did, but it works. And its not like the M5 is some special super secret beast of nature. Its still a motor, and the laws still apply.
http://www.bmwm5.com/vbulletin/showt...threadid=20626
for an example of the IN500 intake.
Your right. But an engine can handle a very small amount of moisture without screwing itself over. At least, thats what people here have told me, and what ive read.
I agree that on a roll, probably not enough water will reach the cylinders to do any damage. If you submerge the opening, you will definitely suck water in like a straw.
Originally posted by Allout
Motors can handle a small amount of moisture. There used to be water injection systems at one time that reduced pinging and knock by in injecting (or misting) water into the intake. Problem comes in when there's not enough air (vs water) in the cylinder to compress & cylinder pressure increases.
like i said, if i let that hole get submerged (i would have to go in to a puddle about a foot deep) then its my own damn fault
Guyz,
Just installed the K&N air filter tonight... Wow, that made it even better... Now the car totally has noticeable pull through the entire curve... You 99ers know that if your right at 60 mph, and you floor it, she drops to 2nd gear and "kinda" accelerates... its a dead zone in our cars... now it pulls like it should... PICS COMING SOON GUYZ!!!!!
