Radio & Lighters no power???
Old Mar 22, 2019 | 08:21 AM
MrSix's Avatar
3rd Gear
Hi all Im new here. My 03 Type S radio and lighter plugs are not working. I've checked the fuse on the driver side it was good. Checked the fuse on the passenger side it was good and the taller 40 fuse under the hood it was good as well. I also took the dash out to see if i saw any exposed wire. Nothing pls HELP.
Old Mar 22, 2019 | 11:21 AM
whitetiger5's Avatar
Try checking the circuit diagram in the service manual (22-198)? There's another component in the system that is controlled by the ignition switch.
Old Mar 22, 2019 | 12:55 PM
MrSix's Avatar
3rd Gear
I just got the car a lil over a year ago and it didn't come with the manual. Im a nit of a novice one i locate that what am I then looking for to then correct.
Old Mar 22, 2019 | 01:08 PM
how did you check the fuse?
Old Mar 22, 2019 | 01:12 PM
MrSix's Avatar
3rd Gear
1st I checked them visually then, I put those fuses in same rated slotes of other components to see if they still work and they did.
Old Mar 22, 2019 | 01:14 PM
Which slot did you check?
Old Mar 22, 2019 | 01:31 PM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
In case you haven't found them, Owners manual and some other documentation are located here:
https://owners.acura.com/vehicle-information/
On my 2001 manual, fuse box layout is on pages 280,281 in the "Taking Care of the Unexpected" section.
MetalGearTypeS
Sep 22, 2014 11:53 PM
roughrider
Apr 27, 2010 08:35 PM
xizor
May 19, 2004 08:19 AM
