radio code error fix
Old Jun 2, 2005 | 02:23 AM
thescoundrel's Avatar
I had to get a new battery for my tl and when it came time to enter the codes for the navi and radio I still had the security card with proper code to restart both. The navi worked fine but the radio kept on giving me "Err-1" and so on. This is not the first time I had to enter the code so I know that I am entering it right.
The serial number matches my card as well. (just turn off the radio, hold on the #1 and #6 button and then turn on the radio power)
I tried to reset the radio by pulling the radio fuse on the passenger side (#9) but same results after re-entering the code.
I was in the process of ripping out the old radio and putting another one I got from ebay, but removing the one screw next to the ODBII port was a b**ch made me stop.
I search this site and the other site and found a little suggestion from the other site that I couldn't believe would work. Pull the antena cable from the radio out and put it back in. It really works. I tried again with the correct code but got err1, but when I pulled the antena cable out and back in, the radio work.
Anyways, I hope this helps those who might have the same problem.
Old Jun 2, 2005 | 04:57 PM
acutee's Avatar
Thank you for having your results here. I have read somewhere of removing the antenna cable, but for some still couldn't believe that would do the trick.
handsom-hustla
Nov 13, 2015 05:04 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
elietania
Sep 5, 2015 06:52 AM
