radiator
Old Oct 5, 2014 | 07:51 PM
ua42014's Avatar
radiator
Hi, I replaced my radiator fan on a 01 acura tl. I attached the two plugs that are on top of both fans. There's one extra put not the same pattern. Does anyone know where it goes?
Old Oct 5, 2014 | 08:13 PM
cominfromafar's Avatar
Casper
Radiator Fan Switch C, which is at the bottom of the radiator. Odd though, as I thought that was only on the J32A2 engine tl's, and the J32A2 wasn't available for 01's. Check though, gotta be something down there that uses it. Someone else will chime in. I'll go check my car for reference.
***Update*** Nope, it's for the AC clutch. Check (feel down) the passenger side fan shroud (left hand side when you're facing the engine) towards the bottom, there should be a female connector you had to clip back onto the shroud. The male side you have plugs into that. Let me know if you need pics.
FYI, Radiator Fan Switch C female connector is smack in between the two fan shrouds, so it's not it.
Old Oct 6, 2014 | 12:04 AM
01tl4tl's Avatar
for a member who has mostly been ghosting for 6 years, you are coming up with the right answers to the weird problems!
thanks cominfromafar !
Old Oct 6, 2014 | 12:50 AM
Casper
They, call, me, Casper... I'll disappear again, don't worry.
Old Oct 6, 2014 | 11:52 AM
01tl4tl's Avatar
Casper eh- do you reflect the sun well too? others are forced to wear sunglasses when your legs are exposed? brightness alert!!
don't go! I'm only back during a break in time, then back spending free time on 2 Honda wheels~
We have a ziner whose real life nickname is `Mr Helpful Diagram` has joined in the party with good info..... and a helpful diagram for every thread!
The half dozen of so of us who tend to have answers need a break!
and to hear the same answers said in new and different ways- helps us learn how to share better= when able to see thru others eyes
Yes I am writing a few books - why do you ask!
TL-Rocket
Dec 4, 2017 06:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 21, 2015 08:51 AM
Sep 17, 2015 09:01 PM
NSolace
Sep 3, 2015 08:02 PM
