Quick Spring Question
Ok, I put on Comptech Springs when my car had about 1000 miles on it. Now I have about 40,000 miles on it and the shocks are starting to lose their control over the springs. I'm thinking of changing the shocks to koni yellows. When I change the shocks, should I replace the springs again with a new pair of Comptechs or should the pair I have now work just fine with the new shocks? Do springs loose stiffness when they are used with shocks with lower damping factors? Are the comptechs just as stiff at 40,000 miles as they were when they were new?
Originally posted by fsttyms1
the springs do settle a little bit but you shouldnt need to replace them, just replace the shoks. Eibach, Koni and Kyb are very good shocks!
You will NOT need to replace the springs... just the shocks.
As for the drop.... the Eibach (Prokit: 2.1/1.7, Sportline 2.6/2.3) is actually quite lower then the Comptech (1.25/1).
Yep the Comptechs are 1.75 front and 1.5 rear. Just about. Gives the car a really nice, sleek raked look. I figured that I didn't have to change the springs when I change the shocks but I just wanted to be certain.
Thanks guys...
BTW, I do have an Eibach Pro-Kit Spring, KYB-AGX Shock and Suspension Techniques rear anti sway bar setup on my '00 Eclipse GT. That's nice for a hardcore sports car-ish feel (espically when you crank up the shock stiffness).
But I like the feel of the Comptechs on my cruise-mobile. I just don't like the underdamped springy feeling I get when I go into dips in the road at slower speeds.
Thanks guys...
Originally posted by steveinathens
according to this site, the CT springs drop is Front/Rear 1.75/1.5
which one is the correct drop? i only ask because i am considering the CT springs for my car...
jmoney2001
Aug 12, 2019 06:23 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
