Quick!!!!!!!!! Need Help!
Old Mar 5, 2003 | 03:49 PM
Comet2404's Avatar
Flyin' and Drivin'
ok, i cant get the filter on the intake part..... its a really tight squeeze, and i'm getting very frustrated!!!! I need some answers ASAP!!! Everything else is OK, but getting the filter on is just not working!
thanx,
ryan
Old Mar 5, 2003 | 03:57 PM
NSXNEXT's Avatar
Take some vegetable oil, vaseline, KY, or any other lubricant and rub a tiny bit on the inside of the rubber part on the filter. Should slide right on.
Old Mar 5, 2003 | 04:02 PM
TypeSDragon's Avatar
Loving my 08 TLS!
make sure you take off the ring and turn it to the left and right to loosen.
Old Mar 5, 2003 | 04:10 PM
ChaosityZ's Avatar
The fitting on the filter is a soft rubber. Mine is a very tight fit as well, but you just have to work it on.
Old Mar 5, 2003 | 04:18 PM
StanMan's Avatar
warming up the plastic helps.
Old Mar 5, 2003 | 05:41 PM
Comet2404's Avatar
Flyin' and Drivin'
Yeah - well, it wasn't going in, I tried everything.... but I did find one thing that works.... duct tape and epoxy (I could care less... nobody sees is, and it wont come off!!!) That ***** is NOT coming apart anytime soon. When I replace the filter, I'll be sure and do it right. How often do you change the filters???
Old Mar 5, 2003 | 08:29 PM
NSXNEXT's Avatar
What? You epoxy'd the filter to the intake? Dude you're ****ed. You don't replace the filters you remove it and clean it with the K&N filter cleaning kit.
I hope I'm just reading your post wrong.
Old Mar 5, 2003 | 11:51 PM
Comet2404's Avatar
Flyin' and Drivin'
Well.... I did.... Its not exactly on there like it should be. I put it on opposite as it should have been installed, but I epoxied the filter to the pipe.... I mean, I dont think its going anywhere. I just slid the rubber inside the pipe, instead of outside it. The filter is on there pretty good. I know, I felt terrible about doing it... But I promise you, it WAS NOT going on like it should have. The filter was simply too small, and I even cut part of the edges of the rubber to try and get it on, but it wouldn't go. I lubed that son of a ***** up, but it still would NOT go on! I was like, "ok, I've spent this much time getting it ready, I dont care what I have to do, this is going on the pipe." My arms were tired, my hands were cut and starting to bleed, so I just gave up. Its ok though, it rained REALLY friggin hard tonight, and I mean HARD. It was yellow and red on the radar, and I guess I didn't suck up any water, so I'm pleased about that. I was all worried about that, but the filter is not going anywhere. It might be a pain in the ass trying to get it off, but maybe then I'll have the money to spend on the AEM V2 by then (and that way I can install the AEM Bypass too!). That should be an EASY install since I've already got the airbox and resonator out. All I have to do is take off the bumper, which is fairly easy. I know I was wrong, but I cant put all that stock **** back in the TL now.... whats done is done, and I might as well leave it until I get the AEM V2.
-Ryan
'99 SSM TL
Old Mar 6, 2003 | 12:46 AM
Darkshear's Avatar
l33t
And the rigging award goes to... :::drum roll::: RYAN!!!!! ::::clapping, cheering::::
Go you dude, I would have done that too, f-ck it!!!
Old Mar 6, 2003 | 03:35 PM
Comet2404's Avatar
Flyin' and Drivin'
LOL... it worked fine today - I floored it several times (I love that noise it makes) and it will be fine until I get the AEM V2.
-Ryan
'99 SSM TL
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
