Quick Maintenance Question
Old Oct 2, 2006 | 05:24 PM
BlueScreenOfTOM's Avatar
Question Quick Maintenance Question
I'm about to take my 99 TL down to the local Acura guy to get the 105K maitenance. He said I could order the parts and bring them in and he'd put them in... I'll save a lot of money that way. He said I need a timing belt, and spark plugs, and recommends a water pump and drive belts.
So, I went on to AcuraOEMParts.com (not necessarily the site I'm going to order from... anyone have better suggestions?) and I found mostly what I need. I'm only having a problem with the timing belt. I see the following here:
11810-P8A-A00 CVR, TIMING BELT 1999 TL 52.18 41.74
11820-P8A-A00 CVR, FR. TIMING BELT 1999 TL 24.20 19.36
11830-P8A-A00 CVR, RR. TIMING BELT 1999 TL 30.36 24.29
14550-P8A-A01 IDLER, TIMING BELT 1999 TL 47.22 37.78
Is the first one the timing belt I need? What are the other 3? Do I need those too?
Anyway, here's the list of parts I compiled:
(One or more of the timing belts above)
19200-P8A-A03 WATER PUMP 1999 TL 116.66 93.33
98079-5514N S/PLG (PZFR5F-11) 1999 TL 17.04 13.63 (Times 6)
Am I missing anything?
Old Oct 2, 2006 | 05:45 PM
fsttyms1's Avatar
I would use this site for ordering parts.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
the timing belt is under camshaft/timing belt
Belt part # is
14400-P8A-A02
you only need the belt, water pump, and i would replace the tensioner
tensioner
14520-P8A-A01
Old Oct 2, 2006 | 07:28 PM
Thanks for the advice. I'll go with that site if you've had good experience with them.
Also... that tensioner is a bit expensive... is it really necessary to replace??
Old Oct 2, 2006 | 07:55 PM
fsttyms1's Avatar
Yes i bought most my parts for the 6 speed swap there.
I would buy the tensioner. Its a simple piece of mind item. (its what keeps tension on the timing belt. If that goes your whole motor goes)
Old Oct 2, 2006 | 08:06 PM
Awesome job on that swap btw... no one believes me about it until I show them the thread. That was pretty amazing.
Aug 15, 2019 12:58 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
