quick clearing headlights help
Old Jun 19, 2006 | 06:30 PM
oVerBoost's Avatar
HELP!
ok so i had my headlight in the oven for ~5 minutes at 250 degrees set of broil. my oven door doesn't close all the way with the headlight in so should i turn up the heat? I'm having a hard time peeling apart the headlight and i've already stuck it in for 3 times. any advice?
Old Jun 19, 2006 | 06:40 PM
fsttyms1's Avatar
use tinfoil to wrap the opening to keep teh heat in the oven
Old Jun 19, 2006 | 06:41 PM
fsttyms1's Avatar
http://www.cardomain.com/ride/184466/18
Old Jun 19, 2006 | 07:17 PM
PenancE's Avatar
lol@that oven
Old Jun 19, 2006 | 07:29 PM
oVerBoost's Avatar
HELP!
mm ok so i was reading austin's diy and it says to make sure to remove the metal clip in the corner on the headlight before baking? what clip is he talking about?
Old Jun 19, 2006 | 07:37 PM
mr.motoring's Avatar
checkmate...
The metal clip is on the edge at the pointed end of the headlight.
Old Jun 22, 2006 | 01:23 AM
victorvu's Avatar
anyone selling theirs or they want to trade i dont really wanna mess up on it if i really go through with doing it.
Old Jun 22, 2006 | 03:58 PM
SSMTL01's Avatar
its not hard man- just take your time and be sure to seal it back up the right way so you dont get any moisture
Old Jun 22, 2006 | 04:05 PM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
try a heat gun
Old Jun 22, 2006 | 05:23 PM
fsttyms1's Avatar
Originally Posted by Da_iLLeZt_TL973
try a heat gun
ovens faster and safer
Old Jun 22, 2006 | 05:29 PM
Phesto's Avatar
BTW -- If this helps,I used the bear trap method to seperate the headlights.
Bear Trap Method--------Use great force(careful dont break tab though) and pull apart and away from each other.Also be care full getting the gray bond on anything shiny or the outside lens itself.Use a spackle knife(really fine one if you can find it)to open up a point to start getting your fingers in.Once that happens just pull with confidence.(BUT CAREFULLY)
from what i have read,this is not a highly recommended way,but hell it worked for me and I love my headlights Most people say use two people,one cutting while the other seperates the housings.I didn't have any support so I did what I had to do.
Old Jul 6, 2006 | 01:37 PM
SSMTL01's Avatar
did ya ever do this?
I did mine a couple of weekends ago and blacked out the housings. Love the look.
Old Jul 8, 2006 | 03:38 AM
victorvu's Avatar
anyone willing to sell theirs or do a straight trade?
Old Jul 8, 2006 | 10:11 PM
Phesto's Avatar
check out that new ebay headlight already blacked out...........but i think its only for 99-01
Old Jul 10, 2006 | 08:58 AM
Acuracy02's Avatar
運転することを愛
LOL. Everyone of these cleared headlight threads has the exact same structure.
1. Quick question
2. Question answered
3. New question
4. New question answered
5. "I don't want to try that, who is selling a set?"
I'm entertained. That said. I have an extra set of lights that I am going to be blacking out, clearing or color matching and will possibly be selling when done (once I decide what I want to do with them). I'll post it in classifieds then.
Old Jul 21, 2006 | 08:26 PM
illTL's Avatar
for those who have cleared your headlights yourself..what do you guys do with the ballast connected to the headlight it self. I took some screw out to move the box...but there a wire that does not wanna come out..some help..lol
Old Jul 21, 2006 | 09:30 PM
Acuracy02's Avatar
運転することを愛
The wire has a connector and it connects to the bulb itself. You need to unclip the connector and remove the bulb and the ballast. If you take that torx screw or whatever it is out and twist off the back cup that allows access to the bulb. If you read the write up that is posted all over here about clearing the lights I think that they explain this step. Check it out. HTH.
-Mike
Old Jul 21, 2006 | 10:23 PM
illTL's Avatar
-Mike
i have got everything out, the bulb and everything, just have a hard time with the ballast...black box
Old Aug 7, 2006 | 01:32 PM
SSMTL01's Avatar
you can bake the lights with the ballast attached. I did it and have had no issues.
IBankMouse
Jun 13, 2020 12:53 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
rockyboy
Sep 29, 2015 12:05 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
mellsonnj
Sep 24, 2015 04:42 PM
