Question regarding the break indicator.
Old Nov 8, 2003 | 07:20 AM
Chien's Avatar
Hi folks!
I had a little problem. Ever since I had my tranny replaced, it has happened twice that after releasing the hand break (leg break... ) the indicator staying on..... which is quite annoying...
It only happens when the temp suddenly drop.. like last night, the temp dropped to -1........ anyone has any idea what to do? Is it under warranty still?
Old Nov 8, 2003 | 07:32 AM
maxx96's Avatar
New Life
More than likely is a sticky switch or because you said that the temp dropped to -1, your pads are sticking to the rotor. The cable might need a little adjustment. Take it to the dealer to get it re-adjusted.
Old Nov 8, 2003 | 07:36 AM
Chien's Avatar
thanks... I'll take it to the dealer and see what they say...
Old Nov 8, 2003 | 09:46 AM
Deity42's Avatar
I had the exact same problem awhile back. The brake indicator would come on if I pushed on the brakes in the early morning and wouldn't go off until I drove for a few miles.
I took it into the dealership and they replaced a sensor in the master cylinder. Only took them like two hours. Problem solved. They probably bumped it or something when they put your new tranny in.
Old Nov 9, 2003 | 07:35 AM
Chien's Avatar
Thanks, sounds like it's the same problem!
Was this under warranty when u did it?
Old Nov 9, 2003 | 09:04 PM
Deity42's Avatar
Yup. Under warranty, no charge.
Old Nov 10, 2003 | 06:32 AM
Chien's Avatar
Since u have a 2000 TL as well, I am assuming it's a 5 years or 100,000 km warranty thing... that's great... thanks a lot!
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
