question on rear camber kit bolt
hey guys quick question ive been looking to buy a rear camber kit and i came across a local seller with a spc kit, he tells me when i go to meet up him that on one of the rear camber kit that the toe bolt is loose but he called a good alignment shop and they said it wouldnt be a problem and it shouldn't affect anything.
what do you guys think? i dont want to waste 80 bucks
ok so i didnt understand what he meant by the bolt is loose so i called and he explained that it was seized when the took it off and now the toe bolt on one camber kit is loose does anyone know if its fixable?
A camber kit and toe adjustment are 2 different things. Also what exactly is seized or loose? Is the toe adjustment bolt seized in the lower control arm? If that is the issue u need to cut the bolt to get the control arm off and replace the control arm. Can you find out more as to what is actually the problem?
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
nuldabz
Sep 3, 2015 05:49 PM
