question on LED lights
Old Mar 14, 2006 | 03:22 AM
69tl's Avatar
I'm planning on replacing all my dash board lights. I wondering for preeps that did replaced OEM light with LED, would you guy be kind enought to show me where you got your LED from and which type of LED did you get, i'm looking at the BLUE LED and i just dunno where and which type of LED should i get.
thanx so much in advance
Old Mar 14, 2006 | 08:20 AM
ProvidenceLeaf's Avatar
Back in a Type S
here you go...
http://www.ledautomotive.com
http://www.tec-toyz.com
Old Mar 14, 2006 | 08:59 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
what he said
Old Mar 14, 2006 | 12:32 PM
aznbeayst's Avatar
my DC5 & 2GTL
can u guys tell me if the leds in the gauge cluster need to be soldered or they are plug and play? only reason i ask is cause i had to solder led's in my rsx cluster
Old Mar 14, 2006 | 01:10 PM
Back in a Type S
Gauge cluster light are all plug-in. Go to the http://www.ledautomotive.com site and there is a nice DIY there for the gauges.
Old Mar 14, 2006 | 01:13 PM
aznbeayst's Avatar
my DC5 & 2GTL
thanks prov, do u guys know the size of the bulbs by anychance.. i think i can get these bulbs cheaper elsewhere if i had known the sizes ? lol
Old Mar 14, 2006 | 01:27 PM
69tl's Avatar
I was thinking of buying the LED ( just the LED alone ) home and solder myself. not like they already made it for you.
Old Mar 14, 2006 | 02:45 PM
Rpappi's Avatar
the quality is prob crap though. there kinda pricy but look at the quality.
Old Mar 14, 2006 | 03:41 PM
Back in a Type S
Well stated!
Old Mar 14, 2006 | 04:01 PM
aznbeayst's Avatar
my DC5 & 2GTL
really? do u guys really think that theres a "quality" involved when it comes to LED's? i mean its an LED.. but i dunno.. neone of pix of SHITTY installs?
Old Apr 9, 2006 | 04:43 AM
Nyshadow's Avatar
Just wanted to know if these LED are brighter than the OEM Bulbs? Thanks.
Old Apr 9, 2006 | 11:16 AM
Rpappi's Avatar
the replacements for the dash or the replacements for the interior?
Old Apr 9, 2006 | 02:03 PM
Back in a Type S
All the LEDs will make everything brighter than stock.
Old Apr 9, 2006 | 02:09 PM
Rpappi's Avatar
not always true.
Old Apr 9, 2006 | 02:29 PM
Back in a Type S
not always true.
It is true if you get the packages from ledautomotive.com
I installed them in my car so I know...
Old Apr 9, 2006 | 03:39 PM
joe80055's Avatar
depends on what type of leds they are... and the higher mcd... for example.. an led that exhibits 8000 mcd is waay brighter than that of 4000...
Dudes.. if you want CHEAP BRIGHT leds... with CHEAP shipping, for example less than 10 bucks.. search for your LEDs OVERSEAS... definitely some good buys there.
Old Apr 9, 2006 | 03:41 PM
Rpappi's Avatar
ya those are the good ones and you prob have the 9 LED's. i have the ones from tectoyz. they are bright but not all are as bright as them. so my comment still stands
Old Apr 9, 2006 | 03:43 PM
1acuratl325's Avatar
ledautomotive.com sends all bulbs with resistors so you always need a resistor to go with your led's when installing otherwise you run the risk of burning out the led bulb. resistors are cheap but led bulbs are more expensive for those who want to buy all the parts themselves go to radio shack but i installed all my bulbs from ledautomotive.com and so far it works like a charm.
Old Apr 9, 2006 | 03:46 PM
Rpappi's Avatar
the tectoyz.com and ledautomotive.com lights are all bright and vary worth the price. highly recomended. i have the blue ones and it is brighter than stock. i think including shipping it was like 35 bucks for all the interior lights. and they dont burn out.
Old Apr 9, 2006 | 03:50 PM
35 bucks sounds bout right for the climate control and clock kit which is 9 bulbs. It takes time but it is much better than the pale green in the end. if you want to go all out blue, i also bought my reverse glow gauges of ebay for $15 including shipping and they glow bright blue at night.
Old Apr 9, 2006 | 03:58 PM
can someone tell me how to post my own thread with my own topic
Old Apr 9, 2006 | 04:06 PM
Rpappi's Avatar
go to the threads page and at the top of the threads there is a button link just click on that you should be able to figure it out from there
Old Apr 9, 2006 | 08:09 PM
sushi96720's Avatar
i agree. i installed the 9 leds and it really not that bright or at least i thought it would be brighter. the light isn't quite white either perhaps because it is not bright per say.
Old Apr 10, 2006 | 02:12 AM
optimus prime's Avatar
So does the dimmer switch work with LEDs or are you stuck with one brightness level?
Old Apr 10, 2006 | 03:27 AM
OntarioTL's Avatar
They will adjust with the dimmer switch.
OntarioTL
Old Apr 10, 2006 | 09:24 AM
Rpappi's Avatar
yup they sure will
Old Apr 10, 2006 | 10:04 PM
Nyshadow's Avatar
I guess both.
Old Apr 11, 2006 | 09:29 AM
Rpappi's Avatar
they should be plenty bright. you have nothing to worry about it being dim. i have the blue ones and they are bright i have a link in my sig that will show you pics.
Old Apr 12, 2006 | 11:38 PM
ledautomotive.com and they have directions on the website
Old Apr 13, 2006 | 03:48 AM
Topher707's Avatar
05 Acura TL: a-spec
i know everyone says ledautomotive.com....... but I have heard there stuff isn’t that bright... Someone on here did a full custom LED speedometer, air controls, and shifter. It was soooo nice... VERY BRIGHT and good quality. He bought all the LEDs and resistors and did it all himself. If your a somewhat good do-it-yourselfer then you can try. it ask him... (ill put up his name when i see it or find it). You can use the ledautomotive.com for the DIY for takin apart the dash and stuff. I think I too am going to try this sometime, if i get around to that ill make a good DIY for everyone. Good luck with whatever you go with.
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
baowheezy
Sep 22, 2015 09:03 PM
drewdeezy03
Sep 3, 2015 08:04 PM
