Question about wiring fogs
Old Feb 27, 2002 | 02:27 PM
CBS
Is it possible that aftermarket fogs can be wired to go off automatically when our high beams come on? The reason I am asking is because in Virginia, and it could be other states, but it is law when your high beams come on, the fogs have to go off automatically. And no, I don't mean turning them off when you have to use your high beams. Can shops handle this request?
Thanks!
Old Feb 27, 2002 | 02:33 PM
songoku's Avatar
BlingBling INSPIRE 32V
Yes, you have to re-wire it though. Buy Accord wire harness and it will work as OEM. (turns on with LOW BEAM and turns off with HIGH BEAM)
Old Feb 27, 2002 | 11:01 PM
liutang's Avatar
Heheh... don't high beam with fogs on when a cop is around. Seriously, I doubt you'll get pulled over for flashing high beams with fogs on.
But if you're worried about it, get the accord harness. If you don't, you can probably get some sort of signal inverter and take the high beam signal and invert it into your parking light signal. Ok, I'm no EE and I don't have helm manual. But I'm sure it should be pretty simple to figure out.
Old Feb 28, 2002 | 07:29 AM
CBS
Thanks for the replies....
You see what happened was that I failed virginia inspection because the fogs stayed on when the high beams were turned on. So they(Acura dealer) had to take them off which I really did not care because I was going to get new fogs anyway. So, just a heads up for my peeps in VA!
Old Feb 28, 2002 | 07:57 AM
Pawel's Avatar
Dude, it's called a switch. When you turn your hi beams, turn fogs manually. Why make things more compleceted.? Just my $.02
Old Feb 28, 2002 | 12:00 PM
songoku's Avatar
Just quick question Pawel, what's up with the Inspire switch in the trunk on your sig???
Old Feb 28, 2002 | 12:47 PM
liutang's Avatar
Re: Thanks for the replies....
Wow! That sux... first they rip you off by making thousands off you.. Then they rip you off by making you pay extra for scheduled service. Now they add insult to injury by being that picky. I had my "inspection" go by with flying colors at my dealer (Pohanka Acura). I had them bundle it in with my 15K service. I don't think they really checked the fog/hi-beam combo, though.
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
