Question about rear turn signal bulb...
I recently put super white bulbs in my reverse lights and I like the way it gives the blue tint look being that my tls is blue. I went out and bought the turn signals too but they don't fit. Every book and even this site say the same thing, 1156 single filiment bulb. However when I took my old one out it was odd, the two tiny tabs on the side that twist into the socket aren't parallel to each other like a standard 1156 bulb. They are kinda offset, thats the best I can explain it. I did a search and found Nada. So I figure I'll nag you guys for some help
I've already done it JPTLS21 ....... got my bulbs from the Pep Boys on Route 9 in Howell and shaved off the higher tab (simply used pliers and twisted it right off) then plugged that sucker in! See you on "The 9"
yah, u gotta clip one of the tabs off. i just did mine on my '03 and it was no big deal. i just used wire cutters and popped one tab right off. just make sure u leave one on, and it will still fit in the harness and hold pretty well. it actually came loose once, but i just pushed it back in and it's held since then.
