question about lowering car
okay im thinking about lowering my car, the thing is i dont have the funds to get lowering springs. So i am going to be doing the drop the "poor man's way" (cutting the springs). I just wanted to know how many coils i should cut. i'm riding on 18in rims with 245/40 tires. i'm looking for about a two finger gap between wheel and fender. any input would be appreciated.
If you are able to afford 18" rims, I would suggest you wait it out until you can afford the springs. Patience is the key!I'm sure most of us here agree that cutting the springs will not make your car happy. It'll hurt your car in the long run. All my buddy's who have cut springs hated their rides after a while. I didn't particularly enjoy riding in their bumpy cars either haha. GO LEGIT!!!
wtfffff?!?!?! cutting springs on a TL dude are FU*** nuts??!!?!?! i had a accord.. i thought the same i didnt even cut them.. i got cheap $80 coilovers.. i blew my shocks and the ride was horrible.. i can imagine what will happen to you if u cut them.. i would only do that to a cheap 95 honda or something.. not a TL.. come on man!!
please DO NOT CUT YOUR SPRINGS!! i'm not sure how much more i can tell you this, but DO NOT CUT YOUR SPRINGS!! you do not have a civic or integra or anything and even on those cars, i would never go the cutting route. TL's are bigger and heavier and if you cut, it will blow your shocks and mess everything up big time. my advice to you is this, if you're not going to do it right, don't do it at all. you'll have more headache in the end and you'll regret ever doing it.
bad idea man, cuttin um just makes ride quality suck, has no performance enhancing bonuses, and after about 10k miles your car will have been rocked so hard by the road shit will start fallin apart. just go rob a bank or steal from the govt for the funds
I would have to agree that cutting the springs is not a good idea, although if that's what you'd like to do, we can't stop you. Cutting the springs will obviously lower your car, but the thing with aftermarket springs is that they are also stiffer as well as shorter. If you're just cutting stock springs, you will most like mess something up in the long run. The springs would not be stiff enough to handle the bumps and you'd probably be hitting bump stops pretty often. That would probably make quite a few things give out after a while, the one that comes to mind first is motor mounts, and I'm sure you don't want to replace those. It's definitely your call though.
Wait for a deal. I even found some Tein SS coiovers for 540 after a bit of searching. Lightly used, but still in great condition. If you can get the 18s, then you should be able to get a decent suspension set up after a bit of saving.
Check the black market, every once and a while there will be a used set for around $600, $540 i don't know but either way cheaper than new.
I will not beat the dont cut your springs dead horse though
Originally Posted by LeeDan00
tein ss for $540? where did you find that kind of deal? i'd buy that that in a heartbeat.
They ended up doing an 03 conversion on it, but went back to stock for all the parts.
