Question about the fog lights mod
Ok so i found this:
https://acurazine.com/forums/showthr...+acura+tl+2002
it says there "You can use whatever means you wish to join wires 3 and 4 together. Just remember you *don't* want to cut them, just splice the two together."
I don't understand how can i splice them together without cutting them?
can someone tell me pls?
Ok so i found this:
but there is the wire right? and i need to connect what inside the wire like g3t0ffma1nuts's picture .. i mean the metal thing ..
how do i get to this metal thing where the electricity is going threw without cutting the wires?
That's a lot of writing....i got a little mind fucked. So I already have the fog light mod where i can turn then on with the high beams. So if i wanted to just turn them on with the parking lights all i got to do is splice wires 3 and 4???
Ok. First you might have to cut a little whole on one side because the wire is ment to go in there and not come out through the other side.
what you do is put the wires in there and make sure they dont move. then used a monkey wrench or something to close the little metal piece through the wires. what that does is cut through the rubber and touches the copper wires directly which lets the electricity pass through them. make sure you close the little metal piece as tight as possible. And make sure you get the right size. since your working with 18-20 gauge wires, the clip will most likely be yellow.
This is the other fog light mod. that i did to mine. i just took a pic of is now.
Ok. This exactly what you need to do. Except your wires wont be cut like his.
http://www.youtube.com/watch?v=Ic_QM82aGls
whats so bad about cutting the wires to tap into them? cut them up, tie the 3 parts together, then heatshrink the fuckers back together so the connection stays put.
i did my fog light mod without any of those quick splice thingamajiggers.
yeah splicing is probably the best way but i just dont have the patience lol.
i believe i have the fog light mod without the high beam mod. i dont see the point of having the fogs on and highs on at the same time. but i guess i dont use my highs that often so i dont really know the benefits.
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
