question about debadging
Old Jul 11, 2012 | 08:49 PM
kuckle1's Avatar
I was bored so I thought I'd debadge my tl I had read the diy a few weeks ago but took awhile to actually do it, stupid me I didn't take anything look before I started today, I took the badges off but don't have goo gone or any substance listed in the diy but I used rubbing alcohol on the 'A' my question is, will rubbing alcohol ruin the paint ? It worked really good, I just don't want to continue if it's gonna ruin the paint
Old Jul 11, 2012 | 10:36 PM
kuckle1's Avatar
Bleep bah bloop
Old Jul 11, 2012 | 11:08 PM
peewizzle's Avatar
i used a heat gun to heat up the badges and then fishing line to floss them out.
with the adhesive, all i had was rubbing alcohol and that worked fine for me. i overloaded my rag with it too and my paint turned out fine...i did wait a few minutes for the trunk to cool first tho since i did use a heat gun
Old Jul 12, 2012 | 12:25 AM
kuckle1's Avatar
Thanks I appreciate it
Old Jul 12, 2012 | 02:11 AM
dreem1er's Avatar
deal with it
alcohol won't do much to anything its not really an abrassive liquid, you can use it on alot of surfaces and not worry about it.
you will probably have a bigger issuse with the emblems ghosted/burned into the paint from being on for so many years.
Old Jul 12, 2012 | 01:45 PM
kuckle1's Avatar
Yeah that's exactly what happened, any advice on getting rid of that
Old Jul 12, 2012 | 07:42 PM
chuckton's Avatar
I wouldn't think alcohol would do to much damage to the paint if any. Worse case scenario may dull the clear coat. As for the burn in maybe try a light compound then wax, wet sand with high grit then compound and wax as last resort.
Old Jul 12, 2012 | 11:17 PM
dreem1er's Avatar
deal with it
a good professional buff would help the burn
Old Jul 15, 2012 | 12:05 AM
cmlteg's Avatar
7th Gear
i just took mine off to, used a bit of alcohol no problem
Old Jul 17, 2012 | 11:21 PM
Ruyguy331's Avatar
i had the acura letters deeply engraved after i removed em, it looked really bad. had it buffed out and now you cant tell at all. best part was i was body work done to my front end so he said he could buff the trunk for free
Old Jul 18, 2012 | 12:22 AM
kuckle1's Avatar
That's legit !
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
