question about chroming 99 shift plate
I just used paint stripper. I sprayed it on, waited a few minutes and then used a rubber blade and it wiped right off. I used a sponge to get in the nooks while wearing rubber solvent gloves. Washed it off with water, dried it off with a MF towel and it came out great. Only took 30mins from removal to reinstall.
Originally Posted by MurdaZ
dont think so, atleast get past the clearcoat, then maybe....when i had my 99 i used a razor blade, took most of it off, then used varsol to take the rest off..
i used a razor blade, had it like at a 10% angle and scraped, i was careful, mine came out mint....but this was done be4 the graffiti remover was discovered....once the clear was off, paint was exposed and the thinner took it off, comes off easier when the clear was removed
dont use a razor blade you might mess somethin up...just use graffiti remover.....just spray it on there wait like 10 minutes and use a garden hose to remove the harmful graffiti remover stuff and plus alot of the stuff will go out with it.
only use paint stripper or graffiti remove
