Question about car idle
Old Dec 12, 2006 | 06:31 PM
greentypes's Avatar
My 2002 tl-s has been idling a little funny lately. I'm sure some of you have heard the sound of an idle that goes up and down. It is not rough or anything, but the idle will go and down gradually. It has only happened two or three times. I have 85000 miles with a remanufactured tranny. Any suggestions?
Old Dec 12, 2006 | 07:04 PM
fsttyms1's Avatar
Sounds like a IAC valve. Its mounted on the bottom of the Throttle Body and needs to be either replaced or taken off and cleaned with carb cleaner
Old Dec 13, 2006 | 07:58 AM
greentypes's Avatar
Question IAC Valvle help
Thanks for the response. My friend at Acura said the same thing. Is it hard to clean or replace? If I replace it how much does a new one run? How long will it last if I clean it? Does anyone have instructions and/or pictures for this type of job? God Bless and thanks again.
Old Dec 13, 2006 | 08:55 AM
phipark's Avatar
Not Asian
It's about $100-120. It's fairly simple to remove. It's probably worth to at least try to clean it first. Then, if that doesn't work, replace it.
Old Dec 13, 2006 | 09:55 AM
fsttyms1's Avatar
Its part #2. Its held on with 2 screws from the bottom. Get a short stubby screw driver and remove the 2 screws. Once out carb cleaner and qtips or a small brush to clean the orfice out.
Old Dec 13, 2006 | 11:30 AM
ecaf005's Avatar
thanks! the same thing happened to me this weekend and had me worried, i will try this
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
datadr
Sep 2, 2015 06:46 PM
