pulley holder questions?
I need 2 more gears
I bought a UR crank pulley and the pulley was removed using a pulley holder, which apparently has 4 small teeth on it attached to a 3' or so breaker bar to hold the pulley in place and then another similiar length breaker bar is used to lossen the pulley bolt. Will this damage the pulley or negatively effect it? The marks are small.
shouldnt have damages it. the marks unless having burs on them wont hurt anything (unless they are big enought to cause a imbalance
That is the specific tool used to hold the OEM pulley. Not to worry, the OEM pulley is designed with those teeth for the purpose of that tool to hold it. Using that tool on the UR is impossible though and if they used it to install your pulley, promptly tell them they owe you a new UR pulley because it may have been scored.
Its my UR pulley. I couldnt take off the crank nut with my SNAP ON im3500 impact gun. I also used my friends IR 1000lbs torque impack gun and a few others and couldnt bust it loose. Me and a co worker had to use the pulley holder and a 3 ftbreaker bar to take it off and it still wasnt easy. The pulley is still in good shape. It just has those 4 teeth marks that wont effect anything. Here are some pictures. It is very small.
http://img.photobucket.com/albums/v...re_32v/Side.jpg
http://img.photobucket.com/albums/v...ire_32v/Str.jpg
sometimes a airgun wont work, and a piece of clothsline rope fed into a cyl by removing a sparkplug will keep the engine from rotating
I need 2 more gears
Originally Posted by Pure Adrenaline
Air gun > pulley holder
Good news is that it'll be fine.
So Pure based on those pictures you feel the pulley is still okay?
i believe it is. if there are any rough spots on the inner trace where the belt may rub on take a file ans carefully file them down
Dragging knees in
Also, the marks seem to be out of the way of the belt. But if you're worried, and rightfully so, you could light sand down any sharp edges on the inner side of the pulley where the indentations are made to smooth things out.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Eggs999bacon
09-24-2015 10:08 AM
