Programming remotes.....HELP!!!
Old Aug 25, 2003 | 08:34 PM
Does anyone know how to program the keyless entry remotes (99-2002)...and yes...I already did a search but didn't find any real instructions. I need to program a remote for a 2000 honda accord ex....I figure it has the same instructions. anyone?? thanks.
Old Aug 25, 2003 | 09:20 PM
Tom Blasing's Avatar
is the Mighty Favog
O.k. This is scanned into an OCR from the Helm Manual:
Transmitter Programming
Storing transmitter codes:
The codes of up to three transmitters can be programed
into the keyless receiver unit memory. (If a fourth code
is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits
between the steps. Make sure the door's, the hood, and
the trunk are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or
unlock button with the transmitter aimed at the
receiver in the passenger's multiplex control unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or
12. Confirm you can hear the sound of the door lock
actuators. Within 1 to 4 sec., push the transmitter
lock or unlock button again. The keyless receiver's
now in the programming mode. You must push
transmitter lock or unlock button of the first
tramsmitter again program that transmitter.
13. Within 10 sec., aim the transmitters (up to three)
whose codes you want to store at the receiver, and
press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door
lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation with the new codes(s).
Old Aug 25, 2003 | 10:38 PM
Awesome...
Great...this is exactly what I was looking for...would any know if all 2000 honda accords come with the keyless entry? If not is there a module or something that needs to be installed? I read somewhere that this is located above the radio inside the dash? Anybody know? thanks..
Dec 7, 2020 05:39 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sep 17, 2015 08:57 PM
Sep 13, 2015 01:59 PM
