Programming Remote???
Old Sep 5, 2002 | 07:26 PM
johnc1010's Avatar
I order a couple of new TL-S remotes. Does anyone know how to preset or program the remotes?
Thanks!
Old Sep 5, 2002 | 07:59 PM
Beason's Avatar
do a search, they have it posted
Old Sep 5, 2002 | 08:27 PM
Here you go!!!
2002 3.2CL with factory-installed security system
2002 3.2TL with factory-installed security system
These transmitters are integrated into the Driver’s
Position Memory System. When the doors are
unlocked with the remote transmitter, memory 1 or
memory 2 in the DPMS is activated, depending on the
transmitter used. When the driver’s door is opened, the
seat and mirrors move to the positions stored in the
activated memory.
DPMS activation can be turned off and on. Press and
hold the “LOCK” and “UNLOCK” buttons at the same
time. The LED blinks twice to show that the feature has
been turned off. Repeating this procedure, the LED
comes on for 1 second to show that the feature has
been turned on.
Programming the Transmitter
NOTE: This system will accept up to three transmitters.
The transmitter codes are stored in a stacking-type
memory. If a fourth transmitter code is programmed,
the code for the first transmitter will be erased.
1. Turn the ignition switch to ON (II).
2. Within 4 seconds, press the “LOCK” or “UNLOCK”
button on the transmitter. Make sure the transmitter
is aimed at the receiver under the audio unit.
3. Within 4 seconds, turn the ignition switch to LOCK
(0).
4. Repeat steps 1, 2, and 3 two more times. Use the
same transmitter used in step 2.
5. Within 4 seconds, turn the ignition switch to ON (II).
6. Within 4 seconds, press the “LOCK” or “UNLOCK”
button on the same transmitter. Make sure the
power door locks cycle to confirm that the system is
in programming mode. Press the “LOCK” or
“UNLOCK” button again.
7. Press the “LOCK” or “UNLOCK” button on each
transmitter you want to program. Make sure the
power door locks cycle after you push each
transmitter button to confirm that the system
accepted the transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the
programming mode.
Ordering a Transmitter
Transmitters can be ordered only by authorized Acura
dealers. Order them from American Honda using
normal parts ordering procedures.
Batteries for the Transmitter
The battery number is CR2025. Each transmitter uses
one battery.
P/N 72147-S0K-A11
(Memory 1)
P/N 72147-S0K-A21
(Memory 2)
Old Sep 6, 2002 | 08:09 AM
johnc1010's Avatar
Thank you so much!!! Very helpful.
Old Sep 6, 2002 | 11:36 AM
FugittiveTLS`03's Avatar
2005 SSM/EB/5AT/Navi
Re: Programming Remote???
Thanks!
Where did you get the remotes from and how much? I'm looking to get one extra.
Old Sep 6, 2002 | 12:26 PM
johnc1010's Avatar
Ebay. $40 shipped. Dealer are asking $70. Maybe cheaper here.
Old Sep 6, 2002 | 02:57 PM
Thanks, I'll keep an eye out for those!
Old Sep 6, 2002 | 03:56 PM
Yaron2's Avatar
good call for a "newbie" ....
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
