"professional" scratch removal
Old Mar 17, 2002 | 03:33 AM
rominl's Avatar
before everything i'd like to thank shyne for the details and instructions. he's been very helpful and let me say the result is awesome!!!
ok here's the deal. if you have scratches on your car, even if it's relatively deep, you should be able to remove big part of it. for those who have seen my car you would know that i got some DEEP scratches all the way to the metal by the stupid mud guards. i tried to touch it up but you know it hardly looks the same again. uneven reflection, etc etc....
after talking to shyne and the guy at the pro auto paint shop here's what you need to do. first go to your yellow pages for the local professional paint supply shop for automobile and get these: 1500 grit wet/dry sandpaper, 2000 grit wet/dry sandpaper (optional, for better results), 3M Imperial Microfinishing Compound Liquid, and the 3M Imperial Hand Glaze. On top of that, you need water, couple of clean dry cloth, touchup paints, lots of patience and time. The two 3M products should be around 1x bucks each.
I'd use my example to illustrate. Remember I got a scratch all the way to metal? I touched it up, but it's not perfectly smooth or as reflective. So I washed the car, and then keep that part wet. Then I also wet the sand paper (it works best in wet). Started with the 1500 grit one first and sand over the scratch. Remember, go in ONLY one direction (ie, back and forth). Don't do it in all direction as it would be hard to clear up later.
Sand it LIGHTLY until you feel that it's smooth. Then go to 2000 grit and continue to fine sand it. Now wash the part again and dry it completely. You will see that the part looks very dull and seems like you have totally fvcked it up. Don't worry, as long as you feel it's smooth using your finger tip it's good.
Now use a clean cloth and apply the 3M Imperial Microfinishing Compound Liquid. You should apply quite a lot of them (don't be cheesy on this one). Use the cloth and rub over the whole area, back and forth, and also in circles. You will notice that it is actually some rough compound. Don't worry, they are there to remove the scratches by the sand paper. This compound will dry pretty soon. Initially you should apply medium pressure but as it drys reduce the pressure.
When it's totally dry, you will notice that the dull looking scratches by the sand paper are all gone. What's left is a whole bunch of swirl marks. This is where the 3M Imperial Hand Glaze comes in, which removes the swirl marks. Use another cloth and apply it. Rub it over the area and use pressure to polish it. Then use a dry cloth to clean up the area.
Congratulations, you hvae just removed the scratch!!! Even if it's down to the metal!!! At least that's the case on my car. You now just need to wax the part and you are done. Well ok, it's not totally gone, you can still see SOME marks, but at least it's 100 times better than before.
For a mere 30 bucks in my case and I was able to remove the marks I can't say more. And BTW, it took me only 30 mins!!! From what I heard those professional body shops? They also use the same products, only they have mechanical buffers to do the job. So if you want to remove everything cleanly, invest another 50 bucks on the buffer
Hope this helps guys.
Old Mar 17, 2002 | 03:56 AM
edgalang's Avatar
Purchased: April 28, 2001
This is great news and all, but for me persoanlly, my ABP + sandpaper = I know I'll screw it up somehow. At least I wont be worrying about it for a while. Cuz if I had my car right now I know my ass would be crazy enough to wake up tomorrow morning just to try.
Old Mar 17, 2002 | 12:05 PM
SleekSatin's Avatar
Great article ! I'll make sure to archive this one
Old Mar 17, 2002 | 02:57 PM
fahoumh's Avatar
Shogun Assassin
when do you apply the touchup paint?
Old Mar 17, 2002 | 04:10 PM
rominl's Avatar
ah sorry, forgot to mention this :p after you clean your car, put the touchup paint on and let it dry for 3 hrs or so. it's ok if you put a bit more than what you should have coz' you will sand it off anyway. but of course i am not saying put excessive amount on it, just a bit thicker is ok.
and well, since my two front side fenders were seriously damaged by the mud guards, i had been thinking about repainting both fenders for some while already. so i figured it's worth a "try". anyway, now the results is sooo good that i can save up couple hundred bucks repainting the whole thinng
Old Mar 17, 2002 | 04:27 PM
NSXNEXT's Avatar
Just an FYI, if you're planning to use Zaino, Blackfire, or any other synthetic, be careful with the Imperial Hand Glaze. It has a lot of oils and Zaino, BF, and other synthetics will not bond to it.
Old Mar 17, 2002 | 07:04 PM
wchan01's Avatar
Can you post some pictures of the end result?? I have the same problem on the right rear bumper!! Hope to see the result and I can start working on it!!! Thanks!
Old Mar 18, 2002 | 02:34 AM
rominl's Avatar
thanks for the info i will make sure i use some dawn later on my car
Old Mar 18, 2002 | 02:35 AM
rominl's Avatar
i don't have pics now but i will try to take some this week. for the before work pic, look at daverman's car in another thread about mud guards and that's exactly what i got.
Old Mar 18, 2002 | 02:42 AM
vperkins2's Avatar
Thumbs up
Ok, I'm listening... What can be used instead of the Imperial Hand Glaze that's still "Zaino-friendly?"
Or are you recommending that we use the Z-5 Swirl Remover at this point?
V.
Old Mar 18, 2002 | 04:23 AM
rominl's Avatar
V.
well i think it's still a good idea to use the hand glaze to remove the swirl marks. once it's done, use dawn or so to clean the area again, apply z1, then z5, z2.... etc etc... that should do it?
Old Mar 18, 2002 | 05:45 AM
Great article. I've got some scrathces that I would love to try this on, but am a bit reluctant to try because they are in prominent areas. Also, I've got some pits in the hood from rocks...does the same procedure work there as well? Thanks.
Old Mar 18, 2002 | 08:26 PM
vperkins2's Avatar
Thumbs up
That sounds good to me! Hey, I tried to track down those 3M products and the sand paper but couldn't find them! Can you give me some store names that I can try? Remember I'm in the Sacto area.
Thanks,
Vincent
Old Mar 18, 2002 | 09:56 PM
rominl's Avatar
yeah the procedure would be the same. BUT, i would highly recommend you to try it on some places that are not as noticeable. i mean, it's not VERY hard, but still practices always help. you wanna make sure you master the technique before touching your hood
Old Mar 18, 2002 | 09:59 PM
rominl's Avatar
Thanks,
Vincent
well the store i went to is right here in san jose so i guess it's a bit too far for you what i did was to lookup my yellow page, go to automobile, and under equipment and supply. i found two shops around me and one of them sells the stuff i got. those are the places you most likely get a reasonable price. if you are running out of options you might also try some body shops that you know are good on painting, but they have rip you off a bit
Old Mar 19, 2002 | 09:11 PM
vperkins2's Avatar
Thumbs up
Well the store i went to is right here in san jose so i guess it's a bit too far for you what i did was to lookup my yellow page, go to automobile, and under equipment and supply. i found two shops around me and one of them sells the stuff i got. those are the places you most likely get a reasonable price. if you are running out of options you might also try some body shops that you know are good on painting, but they have rip you off a bit
Thanks for the info. Talked to some guys at work and found an automotive paint supply store about 3 minutes from my office. Went there and picked everything up! Dang, that sh*t comes in some big quantities... I just have a couple little, tiny scratches I'm trying to remove!
Anyway, now all I need is some free time and I'll get started! Thanks for the great "How To."
Vincent
Old Mar 20, 2002 | 01:12 AM
rominl's Avatar
Vincent
no problem vincent. black and white cars are so hard to maintain, you get a tiny scratch and everyone sees it just make sure you have time and start it with the more unnoticeable place. and yeah those stuff comes in HUGE sizes... a quart!!!!!????? damn
Old Apr 26, 2002 | 02:58 PM
Pawel's Avatar
Thanks for the tips...
Old Aug 22, 2003 | 06:44 PM
6th Gear
Why use 3M Imperial Hand Glaze ???? It dosn't remove swirl marks that well !!!!! On the Rubbing Compound bottle it says "Use 3M Swirl Mark Remover to achieve better results"
Old Aug 22, 2003 | 09:39 PM
Tom Blasing's Avatar
is the Mighty Favog
I've got a bottle of the 3M Imperial Microfinishing Compound Liquid in my basement that's about 7 years old. Still full and good if some one wants to give me $10+shipping for it.
Old Aug 22, 2003 | 11:28 PM
TL Navi's Avatar
sorry i am lil slow so let me repeat what you wrote so i dont eff up .
1) Wash Car
2) Touch up Scratches w/Paint
3) 3 hours drying time then sand them down
3) Use compound and clean the scratches up
4) Use Hand Glaze
5) Enjoy a scratch free panel
Does that sound right and in correct order ? BTW Awesome post thanks a lot
Old Aug 23, 2003 | 10:00 AM
6th Gear
you got it all right.... the 3M Compound does magic..... but don't use the Hand Glaze....its doesnt remove the swirl marks very well,....
Old Aug 23, 2003 | 10:27 AM
fsttyms1's Avatar
im not a fan of the 3m products. me i prefer meguiers. they leave a longer shine and protect longer after all the buffing. that and they dont leave alot of oils like the 3m products do. you can fint the professional grade compounds like the 3m products at most automotive paint stores also
here are a couple lil videos to show you how
http://www.meguiars.com/clinics/clinics_template.cfm
Old Aug 23, 2003 | 07:32 PM
Eternal TL2k3's Avatar
lets see some before/after pics, have yet to see them
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
datadr
Mar 23, 2016 01:39 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
