Problems starting
Old Feb 1, 2013 | 09:51 AM
aimi069's Avatar
Problems starting
Whenever I stop the car and turn it off on an incline I have a problem restarting. When the front end is higher than the rear it creates problems. Acura 99TL, 230K+ miles.
The car is cranking but seems to not be sending any fuel. Another thing is I cannot remove the car from Park. I have the key in (on position) press the brake pedal and try to move the shifter out of Park. If I can get the car out of park I can usually start from Neutral.
I have also on a few occasions pulled the cap next to the shifter and shifted the car into neutral to move the car when this happens.
I replaced the Ignition Switch yesterday, car was stalling while driving, and thought this would solve my restart problem also, but it didn't.
I had a rebuilt transmission put in about a year ago, its working fine but wondering what may be causing the starting problems.
Old Feb 1, 2013 | 01:48 PM
fsttyms1's Avatar
When it doesnt start do you notice the green key light in the inst cluster flashing or anything?
When you cant remove it from park, double check that your brake lights are working when you press on the brake. You may have a bad brake pedal position switch.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
