problems with door lock...need help!!
Old Sep 7, 2004 | 03:57 PM
slixx-tl's Avatar
i have a 99 tl and the lock on the passenger door does not lock anymore when you push down on the automatic lock/unlock switch. it still works when done manually. last night i took out the door panel and tried to take a look around but it's so tight in there, can't really tell. don't want to take it to the dealer cuz that will cost me a grip. anyone here with some advice. thanks in advance.
Old Sep 7, 2004 | 06:54 PM
rjheard's Avatar
You most likely have a problem with the solenoid. Do you hear any sound when you hit the lock or unlock button?
Old Sep 8, 2004 | 10:10 AM
slixx-tl's Avatar
no, no noise at all. i'm pretty sure the automatic lock/unlock switch is still good, just the actual lock itself is no good. i heard something about an actuator going bad. could this be my problem. if so, where is it and how to replace? thanks.
Old Sep 8, 2004 | 10:15 AM
MADCAT's Avatar
I had this problem with 3/4 my door locks. This happened under warrenty and I got them replaced.
Now I just have the one door lock on the rear drivers side lock that ain't working. But since only the front seats are used most often. I won't bother getting it fixed.
Old Sep 12, 2004 | 08:54 PM
MarcL's Avatar
I also have a problem with my 2000 TL door locks. The locks occassionally go on and off for several minutes when the cars is parked in the garage. Other time I open the door with the drivers side control and they all doors lock when a passenger opens a door. I've been to the dealer five time....two new actuators, a new r/s multiplex and a "we couldn't duplicate the problem". It just started again. Too bad the lemon laws don't apply. I've called Acura. Anybody with similar problems?
Old Sep 13, 2004 | 07:04 AM
nayyarn's Avatar
Desi Pride
This happened to me on my first Accord. Open up the door panel, near the door handle. I don't know the technical name of the part, but its a latch that just pops back in to place. It should be a simple fix and you are back in business.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
Azonics
Sep 22, 2015 05:28 PM
brandnewcolony
Sep 12, 2015 10:39 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
