Problems after Gauge Install
So I've installed my gauges, and had to reposition them because they weren't lining up with certain lights perfectly. Everytime I've removed my gauges, the SRS light goes up. Wondering if there really is a problem with the SRS light, or is it just cause I removed the gauges. I keep going to my mechanic and saying to turn it off because he said it might be a problem with electronics on the passenger seat, or my backpack, so I'm not sure if there really is a problem with the SRS.
Also, my climate control is kinda messed up. The mode button, and both defroster buttons aren't lighting up. They work fine, but just don't light up. More of the buttons and the clock didn't function, but I unplugged them and plugged them back in. Not sure if the lights are blown out, or if it is a wiring problem or something.
Any input on how to fix these problems is greatly appreciated
Reset the SRS light yourself. If it comes back on you have a problem, bring it in to be diagnosed. The problem with the lights, is just that. They are very tempermental and just need to be replaced
SRS Reset
http://www.geocities.com/myintegra96/srs.html
SRS Reset
Ive been here soo long now that ive seen just about every problem many many times. Ive got soo many book marks its not even funny
WINNING
Originally Posted by t7n7
i dunno how u do it Kris... u know stuff from everywhere... Do u work for Acura?
always has some kind of answer !
the man knows his acura's
so putting a paper clip into the MES will work? i'm assuming the wires are similar to the TL. Looks like I got something to do over the weekend. thanks kris.
Yes they are the same. It will work alot easier if you use 2 wires that you can just touch together instead of trying to insert it pull it out and reinsert it.
cycdaniel
12-17-2019 10:58 AM
brandnewcolony
09-12-2015 10:39 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
