Problem with power window!
On my 03 tlS you know how when you click the window opener for the driver, but if you press down all the way it should sink down on its own, well mine doesnt do that, what could be the problem, it openes find, just not on its own?
6G TLX-S
Try to reactivate the auto down function.
Start the car, hold up the window switch for 3 seconds, then roll it down still holding it for 3 seconds, then try to use the auto up. If you disconnected your battery recently it has to "re-learn" the feature.
this happens when the window control loses power either from disconnecting the battery or removing your door panel and unplugging the harness. that reset should defiantly fix your issue
k6biv
09-10-2015 06:37 PM
ahsm
09-09-2015 08:35 AM
