Problem with my thermometer.
Old Aug 27, 2009 | 07:28 PM
Bonta-Kun's Avatar
I have 03 TL-S, and about 2days ago after oil change my thermometer shows 78 F all day long, even tho it's like 100 F outside in Texas.
If anyone have any tip info. I'll be really appreciated.
Old Aug 27, 2009 | 08:08 PM
01tl4tl's Avatar
the sensor is located in front of the radiator, bottem middle on a bracket
Make sure its wire is hooked up
Old Aug 27, 2009 | 08:09 PM
01tl4tl's Avatar
it is possible to adjust the temp reading/calibration by accident when resetting the oil change reminder system but thats only a 5 degree either way range
Old Aug 27, 2009 | 11:25 PM
Bonta-Kun's Avatar
I'll take look of that tomorrow morning, thanks guys!!
Old Aug 28, 2009 | 06:38 AM
webmastir's Avatar
2003 TL
how's that possible? i mean...of course know how to reset the oil chg reminder, but what does that have to do w/ the temp stuff?
Old Aug 28, 2009 | 10:57 AM
01tl4tl's Avatar
if you turn the key ON then push the 2 buttons it goes into temp readout mode instead of oil reset-
there you can adjust it to a known temp like a glass of freezing water should read 32
,,adjust to correct
In the OPs case it may be damaged sensor or wire,,,something damaged by low paid oil changer possibly? like if they used a chain on the car so it doesnt drive off with no oil- that could have hit the sensor
Old Aug 28, 2009 | 01:15 PM
webmastir's Avatar
2003 TL
oh, ok...thanks
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
