Problem with car starting. Dont know what to do.
For the past couple weeks i've been having problems with my car starting after being warmed up. The first time it happened, it was late at night and i just ended up leaving it where it was for the night and then bringing it to my mechanic the following morning, in which it started up fine and my mechanic couldnt find any problem. This problem only seems to occur after say i drive for a while, park somewhere, turn the car off and then try to restart it 10min or so later. It still always fires right up on a cold start. It sounds like the car isnt getting fuel becuase it cranks over fine. Im thinking the problem has to be with some sensor. Has anyone had a similar problem?
how many miles on the car, using 91 octane gas? from where?
Has the battery been tested?- parts stores do it for free
Most batteries are lucky to get 3 years- 4 is really good lifespan.
Ever changed the spark plugs?
have you done the new foam method AT the TB vac port- not the skinny line on the side?
Need to do a cleanout of the gas tank and intake- a few days later install NGK Iridium IX plugs
The battery may appear fine and start the car once, but then doesnt charge right back up full- or it would start the 2nd time, 5 years old- that things a doorstop in waiting!
A lot of things would have to be wrong for fuel to be an issue at this point of the diagnosis
Test battery at store first
nanos
11-12-2015 08:41 PM
