Problem with CAI Someone Please help
Old Jul 31, 2001 | 05:42 PM
ChinozTL's Avatar
I installed my intake today and then decided to go outfor a spin. Something is very wrong with the install. If I floor it the car wont shift out of the current gear. Like a big flat spot after 5000rpm and thn the rpm drops down drasically and wont get out of that gear but I still have my foot on the gas pedal. What could I have done wrong?? THe only thing I can think of is not puttin the 2 little hoses on properly. I put the one in the front on the front little hole and the one in the back on the back little hole. Can someone put some insight on this sitution please. I followed the directions on this forum for installation.
Old Jul 31, 2001 | 05:46 PM
unx979's Avatar
maybe unhook your battery so your cpu can reset. and make sure there's nothing stuck in the tubing or the filters.
Old Jul 31, 2001 | 06:22 PM
ChinozTL's Avatar
I tried checking all the hoses and they look ok and I disconnected the battery and put it back on. Still having the same problem.
Old Jul 31, 2001 | 07:03 PM
Nate's Avatar
Dude, make sure the pipes are clear! Maybe something got sucked in your intake or is blocking it? Are you using the by-pass valve?
Old Aug 1, 2001 | 02:14 PM
ChinozTL's Avatar
No im not using the by-pass valve. Thanks for the help from the guys that replied. There was somekind of tubing stuck inside the filter that had to be taken out. Runs fine now and sounds great.........The CAI really makes a difference.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
