Previous owner used Regular gas for years - what should I do?
I prefer to use premium, but the previous owner switched to regular when gas prices went through the roof.
Anything I should do besides using 91/93? Any kind of additive I should put in?
thx!
thx!
yeah, it's in really good condition. I'll try to get some pics soon and post. Its silver and stock. I'm going to tint the windows and put in a new HU with Sirius next week.
1 can of seafoam in the gas tank and a can of seafoam in the intake manifold vac port
Clean the TB with carb cleaner or Deep Creep
repeat in a month then install new NGK Iridium IX spark plugs
You will be good to go- also need to reset the ECU after cleaning everything- it will have adapted to the lower octane
91 or higher isnt a choice- the engine needs it
Phee- it wont clean the intake manifold by putting it in the oil- what are you thinking?
It does a great job cleaning the oil passages inside the engine that way, and probably the oil pickup tube screen--
I use a fresh oil filter and drive more than most would with seafoam in the oil-
also use vtec as I heard gen3 issue with vtec sliders gumming up and not working- big dollars to replace, so keeping mine clean~
Must put it thru the main vac port to clean the intake manifold, even then its not going to get everything.
Every 75k miles or so its wise to pull the manifold and clean the EGR ports and intake runners, that the only way to clean the egr ports
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Clean out the EGR port, prob has alot of grit pilled up inside from the regular gas.
I also used regular gas when gas was alot well 1 fill up reg 1 fill up mid..My car runs fine, im gonna clean out my EGR port next week and install some outlaw engineering spacers.
B A N N E D
here is a pic of a egr port of a diff member ..
and this is pretty much how to get to it...
DO not drill anything thats only for 99tl's
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
its better to pull the clock fuse than disconnect the battery to reset the ECU-
the battery method requires resetting the radio and nav security codes
Its possible to damage the cable ends or battery post with deadly results to the battery during removal or install of the cables!
If your battery terminals need cleaning anyway- this is a perfect time-- so do the battery method, just use care with tools and use your eyes to see whats happening
the Seafoam video on youtube says to use 1/3 can into the pcv valve or vacuum line, 1/3 into the oil crankcase, and 1/3 into the gas tank.
http://www.youtube.com/watch?v=D11ZVYwj62w
Is this what you guys do?
eff utube and anyone not using a TL as demo car- as we have done in several DIY thread on here
when you have azine you dont need utube for instructions
We do it MUCH better by using a full can in 1/2 tank of gas
a full can in the intake manifold vac port at the TB, the brake booster works but this is better
Oil- put some in right before you are going to change it
They dont cross over--intake does not clean the oil, and oil does not clean intake
the 1/3 can per area is marketing
read the website and it says to use more, example-- 2oz per gal of gas-- is cleaning dose
how you get that with 4 oz is beyond comprehension
B A N N E D
Just do the VAC line and the gas tank 1/2 and 1/2 thats what i did!
Hi goMo :
I've been using regular gas for years with no issues. If it were me I'd say enjoy your car and don't worry.
Now, engine mounts are another matter.......
smartypants.
smartypants.
6MT Someday..
I tried regular 87 a few times in mine-only noticeable difference is performance suffers, and mileage as well. Two tanks it averaged -60 miles compared to premium. Theres a few on here that swear by 87...but I dont want to open that can of worms.
Far as seafoam-do what 01tl4tl recommends. It worked wonders for my vehicles!
Traded in my
^^I feel like I'm going to open up that can twisted..
I swear I've been gettin the best mileage with 89 octane. Recently went on a 1200 mile roadtrip (there and back) and got a lil over 29 mpg on an 89 octane tank in cali - premium got way too expensive where I had to fill up so I went with 89 for a tank.
Then did premium when it got cheaper again and got bout 27 mpg. Didnt really drive any different with the two tanks..cruise most of the way as I was mostly on I5...
The Dumb One
just for everyones info... although gas prices may seem high.
on average the difference from 87-91/93 in price on an ENTIRE tank..
about 3 bucks most cars a little over 2
if you fill up once a week... your saving about 160-170 bucks a year.. not breaking anyones bank IMO
getting to the egr port looks to be not as simple as I would like, especially considering I don't exactly have a green thumb with this kind of thing. How much do you think my regular mechanic would charge to do this?
My mechanic who charges $50 an hour estimated $50-$75 for my 2000TL which seems consistant with the 99 EGR recall service.
I'll probably do it myself. My main concern is how to responsibly deal with the mess.
the reason you wait to add seafoam to the engine oil until right before change is that it breaks loose tons of sludge
10 minutes engine running is ok, more than that and I would install a new filter to catch all the stuff
Thats the problem- the old filter already is nearly full- then you add more--reaches its limit and it goes into BYPASS mode- which means NO oil is going thru the filter
If you are at the end of the oil filter lifespan or have a known heavy grunge engine- it may take a few filters and oil changes to get it all out
But you have revived an otherwise dead engine!
6MT Someday..
^^^ lol are you serious? I averaged 26 the last tank with mixed city/hwy driving..
My best is 32 on the highway....with premium..
murky: you can do that EGR clean-its easy. Just take your time and follow the DIY posted. the non type-s is especially easy..
why are people using 87 octane in a 91 minimum car? says right on the gas door-
not 91 `suggested`
91 or higher required
especially Type S cars with their even higher compression engine
You may not feel a loss, but its not good for the engine and the 2-3 bucks per tank more is no excuse- give up a soda or something to pay the differance
Thats part of owning a performance car-vtec doesnt run cheap
not 91 `suggested`
6MT Someday..
^^^ I agree 10000000000%
you CAN run 87-the ecm will compensate for it, but when you go to open up the throttle it will speak for itself..
Filled up yesterday@2.79/gallon for 93 octane. took 13.3 gallons. 13.3x2.799=37.22..
Regular 87 octane is 2.599/gallon 13.3x2.599=34.56
37.22-34.56=2.66. Not even enough for a gallon of premium..lol.
If that 2.66 ruins your budget you have serious problems..
I dont mind the price for the TL,,,thats part of owning it
But my 2 wheeled honda requires it too!
Same 9 to1 compression- rev loving vtwin monster
Do you know how much that 20 cents a gal adds up to,,, at a whopping 3.some gallon per fillups and 40-45mpg~
My all day road trips cost 10 dollars!!!
bummer
bummer
I know- the funny part to me is the 87 users who say it doesnt harm the engine!!
Yet none have done a boroscope inspection to see what crud is being left behind
A job for Seafoam~
my bike manual calls for a seafoam type `decarbonizing treatment' fairly often, to remove carbon from the piston tops
In these zero tolerance/clearance engines its possible to build up high enough carbon layers on the piston to contact the valves!!!
A job for Seafoam~
I just drove 400 miles today. Averaged close to 80mph on the highway from northern NJ to Baltimore. Had the a/c on also. Got 32 mpg!!
Can't wait to do the seafoam and clean this sucker out!
6MT Someday..
its pretty cool, eh? v6 with decent power and 32 hwy...not a bad balance!
I havent taken a road trip since the total seafoam...hmmm
damn ok i'm gonna switch to 91 asap. Ill burden with the extra cost. I never really looked to see what gasoline the car required, but yea i shall switch!! I also need to seafoam this car during summer.
edit again: haha i just realized i pressed quote instead of edit my bad
