pre- lube oil filter?
i heard that you should pre lube the filter b4 putting it on the car?
i am using m1 105 and i wanted to know wxactly what tha means? put oil in the filter hole itself? or just fill the hole then drain it then put it on?
also is rubbing a little oil on the seal a good idea?
Just did an oil change this weekend. Poured some into the filter and did the rubber seal. The idea with the oil on the seal is to help prevent it from fusing, so the next time you do an oil change, the filter and seal come off as one piece.
You fill the filter through the large threaded end before installation b/c you want to reduce start up oil starvation (the time it takes the oil to reach the important parts), lubricating the gasket reduces the chance that the cheap rubber will stick.
Fill the filter as full as it will go. It takes a couple of minutes for the oil to absorb into the filter, then you can pour more.
Since the TL filter is vertically mounted, it makes it easier to do this and not get messy.
Dragging knees in
Definitely wet the gasket on the new oil filter. It's not a bad idea to fill up the
chamber as well to minimize oil starvation on start up. I usually pull the EFI fuse
and crank the starter till the oil light goes out so I know it's primed.
Filling the filter on the TL is not a bad idea since it is installed nearly vertically.
/Steve
/Steve
Dragging knees in
Originally Posted by Jeremy610
don't fill the filter too much because it has a slight angle when installing... i filled it up all the way and spilt oil all around the filter.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
My buddy has a GS-R and I stopped by when he was doing his oil change. I told him to fill it up before plugging it in, so he was like "OK." Fills it up, gets underneath the car, and next thing I know, he's cussing up a storm. He rolled out from underneath the car and he was SOAKED in oil. I asked him what happened, and he goes, "Man, the B18C has the oil filter mount right up to the block horizontally."
I just about fell over laughing.
rcs86
08-02-2016 06:52 PM
