Power steering
Old Apr 4, 2011 | 10:51 PM
lost1's Avatar
6th Gear
Power steering
I took my 99 TL to a shop I have used before to have my tension pulley replaced and EGR valve duct cleaned out. When I went to pick up the car, the owner told me that I need to replace my Power steering pump because the bearing made a ringing sound and the power steering fluid was surging. He said it would not last much longer. When it was colder the power steering pump made a noise but went off after it warmed up. I noticed that they had changed the low pressure hose and the power steering fluid. Now the power steering pump makes the noise and would not stop. When I drop off is did not make any noise. I am under the impression he messed with it so the sound would annoy me so I can come in and have it replaced. Any suggestions? Should I just replace it? The sound is annoying.
Old Apr 5, 2011 | 11:03 AM
01tl4tl's Avatar
they may have tightend the belt so now it really makes noise
or its finally worn out
What fuid was used when they replaced the ps hose? that can make a differance too
Old Apr 5, 2011 | 12:06 PM
fsttyms1's Avatar
My guess is that they overtightened the belt and ruined your pump.
Old Apr 5, 2011 | 04:30 PM
TLer trash's Avatar
It's also getting to be pretty common for the ps pump inlet o ring to start leaking if the pump's been nudged. It's definitely the cheapest and easiest place to start. It will suck air, with no fluid leak, so it's easy to overlook.
Old Apr 5, 2011 | 05:16 PM
01tl4tl's Avatar
good call trash--lets hope its the cheap fix
and not the shop adjusted belt and now pump finally quit after a year of noise~
Old Apr 6, 2011 | 08:18 AM
lost1's Avatar
6th Gear
01tl4tl : The shop specialized in Honda repair, so i think it's Honda PS fluid used.
Trash : After reading another thread i had one of my friend who work close to the Acura dealer pick up 2 rings for me. Will give an update after i change it later today.
Old Apr 25, 2011 | 03:51 PM
slowboat's Avatar
Same problem on mine. Any update? Did the o-rings fix the prob?
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
