Possible warped rotors on 02 Type-S
I noticed that my steering is shaking more noticably at high speeds and that my car wobbles somewhat when braking. I believe this is a result of my rotors being warped, as others on this forum have described. My 02 has 11200 miles on it. Do you believe Acura will cover rotor replacement or resurfacing under warranty?
mushroom mushroom
yes they will cover this issue. I just had my roters resurfaced at 13,000 mi. The dealership will not cover the issue but Acura will. Now go make that apointment.
Sounds like your wheels might be out of balance as well. It's a good idea to have a wheel balancing and alignment done regularly. At least once a year. If you have warped rotors, you would really only notice a vibration in light braking. So a good little test is to see if the vibration is there under light braking, but goes away as you squeeze the calipers more as you come to a a stop.
want issues...try a german car....rattles, squeaks, recalls....Acuras for the most part are so tight adn trouble free. If the 6 speed CLS was available when I bought my A4, I'd probably have spent the extra $$$ on the CLS and had less to worry about....and had a faster car.
08_UA7_Gr33k
02-11-2016 02:17 PM
DerrickW
11-15-2015 05:52 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
