Is It Possible!?
Is It Possible!?
To Lose 2 Ballast In 2 Weeks?
I Was Putting On Hid Fogs In The Morning And One Side Worked Great! One Side Was Messed Up Already! After That I Washed My Car. So I Get Out Of Work And I Drive Off I Didnt Want To See The Hids In Action Until I Got Somewhere Dark. I Get Off The Car And See The Fogs Loved Them But Then I Notice That My Working Headlight Is Out Tried Flicking Them On And Off Nothing. Im About To Give Up?
Any Reasons Why I Lost The Second One?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
And these headlights are expensive!!
My passenger one used to flicked and not come on sometimes , so i just go off on off on and it would work, but for like 6 months it worked perfect!
NOw its acting up again WTF!!!!!!!!
Umm Idk There The Oem Stock Bulbs. Before My Working Side Messed Up I checked If The Side That Was Broken Worked So I Switched The Bulbs And It Worked So This Means Its My Ballast Right?
[warranty? no i dont think so i guess i have to go and buy 2 ballast
quote=ProjectTLS;10673119]More than likley. Do you have warranty for the units?[/quote]
The fact that you washed your car, then killed the ballasts means that you've likely got a moisture leak somewhere in the system dumping water onto the ballasts. The number one killer of ballasts is moisture. they get moist, then they arc across, as they are a high output electrical device, then bingo, dead ballasts. Look up my postings, as I suggest when you replace them, you seal the connections with clear silicone caulk. Five bucks worth of silicone saves you a goofy amount of money on replacement. And there's always new OEM ballasts for sale on EBAY.
