"poof" sound when starting engine
Hello all,
not sure if this is a normal "problem" but my acura tl-s sometimes makes a "poof" sound when it is started. it comes from the engine area and sounds like there's pressure that's built-up in the cylinders. it does not happen all the time and is not affected by the AC or anything else. is this normal???
thanks
thanks
There was another post in the TL forum regarding the same issue. I posted there that I am having that same kind of issue. Although, unfortunately, I don't care for it!!
Here it is:
http://www.acura-tl.com/forum/showth...threadid=24374
Here it is:
According to Acura this is normal. My wife inquired about it and the svc. mgr. gave her some technical answer about vacuum pressure. Anyway, the 3 weeks we had a CL-S loaner, that car did the same thing which did at least prove that it's a design feature (or flaw) inherent to all Acuras.
Hope this helps but if not...just ask your svc. mgr....don't make your poor wife try to remember the technical stuff and then relate
